Clutch pivot bolt removal - ST 1136
darrellw
Postby darrellw » 15 Jan 2015 12:46
ST 1136, this is the tool to use to remove the clutch lever are pivot bolt. Anyone know what head is on the pivot? Will a crowfoot wrench have enough reach?
Thanks!
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby john 215 » 16 Jan 2015 04:26
Hi Darrell,
I am sure I just use a deep socket, will check over the weekend what size you require and get back to you.
whitenviro
Postby whitenviro » 16 Jan 2015 04:49
Darrel: The pivot is 3/4" or 19mm. A deep socket will do it. But a socket won't work if you are trying to remove the pivot with the fork still in place, like the manual says you should. Forget that. Just reach behind the fork and wiggle the fork spring off the ball of the pivot, then you can slide the whole release bearing and fork off together. Much easier!
[/img]
darrellw
Postby darrellw » 16 Jan 2015 12:52
Thanks!
Yes, I was asking about removing the pivot with the arm in place, like the manual says. But I'll just remove the arm.
I also Googled ST 1136 and found this Snap On tool:
http://www.ebay.com/itm/Snap-On-Tools-3 ... ls&vxp=mtr
Looks like it would be just the right size, too!
Darrell Walker
Vancouver, WA, USA
Users browsing this forum: No registered users and 40 guests
