Stuck driver door
Sean Roth
Stuck driver door
Postby Sean Roth » 16 Oct 2014 03:29
My driver door all of a sudden started getting stuck. I have to pull it really hard to open it. Any usual suspects I should check?
SF Roth
Postby Odd » 16 Oct 2014 03:33
FHC or DHC door?
Sean Roth
Postby Sean Roth » 16 Oct 2014 03:51
Convertible.
I think Drop Head..... Assuming that means rag top??
SF Roth
Postby John Clancy » 16 Oct 2014 06:59
It's not unusual with the floppy drophead body. The knack is to pull the lever (the inside lever) and with your other hand give the door a bloody good whack in the middle. Others can advise you better but that's essentially it.
As far as I know, this doesn't happen with the coupe. I've certainly never had it in 30 years and I've had just about everything else in that time.
Postby dursleyman » 16 Oct 2014 07:34
Check that the anti-burst catch is lubricated and not sticking.
1981 TR7 Sprint DHC
Postby TR Tony » 16 Oct 2014 08:01
Agree with Russ, clean & lubricate the anti burst catch above the lock on the door pillar.
Sean Roth
Postby Sean Roth » 16 Oct 2014 21:57
Is that part of the lock assembly?
SF Roth
whitenviro
Postby whitenviro » 17 Oct 2014 00:04
It is separate from the main latch. It is the upper catch on the rear of the door frame. Spray it well with penetrating oil until the sliding wedge part of the latch will move in and out freely. Then I blew out the oil and dirt with compressed air and worked some light lithium grease in under the wedge. I've had no problems with them since.
[/img]
tr7jim
Postby tr7jim » 01 Nov 2014 20:16
On cleaning up the anti-burst catch it should spring in and out e.g not stick at all.
I good knock on the inner door helps and sometimes just moving the car will help into a different position.
Jim
Postby jclay (RIP 2018) » 01 Nov 2014 21:59
The latch is really a wedge in a housing mounted to the door frame. Question: When you open your door, do you hear a clicking sound about 5 seconds later? That wedge gets gunked up with dirt and sticks. When you open your door it should move immediately. Spray the whole thing with WD40, then use your finger to free the wedge until it slides freely. Clean everything up and oil the latch with some engine oil.
There are several components of the drop heads that have been left out of you usual catalog illustrations like this door anti burst latch and the window stop.
Users browsing this forum: No registered users and 43 guests
