Gearbox extension loose and rattling!
Dougdavie
Postby Dougdavie » 15 Sep 2014 07:22
I have had a rattling noise when changing down gears for a little while and thought it would be the anti rattle spring and pin come adrift etc.
On investigation I found the whole rear extension (where the gear stick goes in) moving around.
It's quite inaccessible from inside the car despite me stripping out the trim around the gear stick and removing the access panel.
I need to het the car on a ramp to investigate further.
Has anyone had any experience with this and is it likely to be a case of just bolting it back up (using correct washers etc).
Any help much appreciated........
Doug
1980 TR7 DHC
Postby john 215 » 15 Sep 2014 07:46
Hi Doug,
I assume a five speed box ? In that case the bushes for gear selector housing have fallen part, a reasonably common fault. Replace them with poly bush type and you will be fine. Available from all suppliers as these from Robsport -
https://www.robsport.co.uk/index.php/ct ... lyurethane
Can be done from inside the car, with centre console removed, easy enough to do just a bit fiddly, ensure the lever assembly is located in the pin coming out the box when going back together, very frustrating in you change the bushes only to find this has slipped out [:(!]
http://www.forum.triumphtr7.com/topic.a ... gearchange
Postby FI Spyder » 15 Sep 2014 13:53
My bet also. Mine had completely disintegrated and fallen off. I did mine from underneath putting the car up on jack stands. This gives you a chance to get under the car to get a good idea what is involved re: general condition and other jobs, tire rotation etc. etc. Not so easy if you don't have a garage, uneven ground, soft ground and/or sloping ground etc. in which case from above will be the ticket.
kstrutt1
Postby kstrutt1 » 15 Sep 2014 19:17
Did mine from underneath as well removed the gearbox x member and dropped the rear of the trans a couple of inches to make more room.
Dougdavie
Postby Dougdavie » 16 Sep 2014 10:16
Many thanks for all replies. Really helpful. New bushes will be ordered today. Will keep you posted. Thanks again
Doug
1980 TR7 DHC
Ianftr8
Postby Ianftr8 » 18 Sep 2014 19:18
When you lift out the gearstick take care not to loose the spring and its cap that stops the stick rattling.
Ian
Ian Freeman
1979 TR8 DHC KDU 315V Poseidon Greens USA car that never crossed the pond.
Triumph Courier
Triumph owner for 32 years
kstrutt1
Postby kstrutt1 » 20 Sep 2014 19:11
There is a good chance the cap will be loose because the bolt tab has cracked off anyway, virtually all the ones I have worked on seem to be.
