Clutch stuck or broken
alansti
Postby alansti » 14 Sep 2014 19:46
Hi All,
My Seven has been standing for a year, I'm trying to recommission it but the clutch doesn't seem to work at all now and the gears crunch, I've changed the Master and slave cylinder seals but it still doesn't work. If it's just the friction plate rusted to the flywheel is there a recommended way of freeing it without removing the gearbox? I know that the clutch forks also break, I guess this would give me the same symptoms.
Postby dursleyman » 14 Sep 2014 20:00
There are several ways, the one that always works for me is to get it warmed up and switch off. Put it in first and start it - you are now kangaroo style down the road. Now, holding the clutch down keep going on-off-on-off with the gas pedal and it WILL suddenly free.
Sounds very drastic and needs some clear road but never fails.
Image ImageImage
alansti
Postby alansti » 14 Sep 2014 21:31
Thanks Russ, Are there any other ways to free the clutch? the car is in a difficult location.
parrish
Postby parrish » 15 Sep 2014 01:36
Unfortunately not,
I had the same problem last year, due to my car being parked in an awkward spot, in an underground garage against a wall, I had no option but to remove the engine and G Box from the car (and mines a V8), as soon as I touched the clutch plate with a screw driver the thing just fell off.
Oh and yes you can remove a V8 through the top.
1983 Del lines TR8. FIAT 131 Abarth Replica.1977 FIAT 131 1600 TC, 1996 2013 Fiat 500, 2012 Ford Fusion.
Postby FI Spyder » 15 Sep 2014 01:47
How about putting the rear on jack stands, putting it in whatever gear, starting it and as the rear tires are turning with the clutch pedal depressed jamming the brakes. You might need higher revs than idle so a second person under the hood to activate the throttle.
alansti
Postby alansti » 16 Sep 2014 08:04
Thank you all for your responses, I managed to bump the car back out of the driveway into the road on the battery with enough time to check on coming traffic, which I'd been worried about. Then did the kangaroo hop up and down the road as per Russ's suggestion until it cleared.
Grant Hull
Postby Grant Hull » 17 Sep 2014 10:18
Will this work the way Spyder has suggested?
Postby saabfast » 17 Sep 2014 10:39
Yes, but make sure the car is secure and firmly on the axle stands. I used to have an infrequently used Imp (due to engine maladies) which I used a similar method on, but had it pulled up to the top of the long downhill drive we had then and drove back down declutching and braking. Have also heard of the car being nosed up to a substantial tree and a similar method used. It is best to get it hot first so that heat soaks into the clutch assembly.
RadioGuy
Postby RadioGuy » 17 Sep 2014 20:54
The "Kangaroo Hop" works here as well...at least twice.
Maintained on Saturday…Drive on Fun-Day !!! 1976 FHC - 1980 DHC http://tinyurl.com/7rkonrx
Users browsing this forum: No registered users and 17 guests
