4 branch manifold and Starter motor
smoking joe
Postby smoking joe » 07 Sep 2014 11:25
I think I may well have missed a trick, installed the
replacement manifold for the std. cast one, then tried to
fit the starter motor heat shield, no go !
Should this have been fitted first ? but suspect it would have been
knocked off if I had tried, what is the procedure here ? Leave off and
wrap that section of the manifold with heat reflective foil etc ?
Thanks.
SJ
John Wood
Postby John Wood » 07 Sep 2014 12:15
I bet there are a few running without the heat shield.
TR7 Sprint & TR8
Postby gaz » 07 Sep 2014 12:41
I've not had a problem running a four branch without a starter heat shield
1981 DHC 2.0 Litre
1980 DHC pedal car
Postby Hasbeen » 07 Sep 2014 15:17
I don't have a heat shield on the 7 or the 8.
No problem in 12 & 9 years so far.
Postby FI Spyder » 07 Sep 2014 15:55
When I put on gear reduction starter I made my own heat shield out of a piece of aluminum I had lying around as old heat shield wouldn't fit small motor. I used the mirror image of a Chevy starter heat shield as it's mounted on RH side. Don't know if a gear reduction starter would work better on your set up re: room as the solenoid is as big as the starter motor. I think a ceramic coated manifold looks better than a wrapped one. It seems from Hasbeen that it's optional but I would rather ere on the side of caution for the long term.
Postby saabfast » 07 Sep 2014 16:49
I do not have a starter heat shield with a tubular exhaust. I wrapped the cables to the starter with aluminium foil to give
them some protection from the heat.
smoking joe
Postby smoking joe » 07 Sep 2014 18:21
I was thinking about wrapping the wires with foil in the short term, and
then wrap sone aluminium heat mating around part of the starter etc and secure with metal cable ties. But it seems then that most of your don't worry about it, I think as a precaution I shall take the advice of of Saabfast here. Thanks for your help.
SJ
Postby Workshop Help » 07 Sep 2014 19:14
My heat shield is intact and not all that difficult to remove or install on my engine with the Pacemaker exhaust header.
Users browsing this forum: No registered users and 12 guests
