ACG97
ACG97
Postby Chris Turner » 01 Sep 2014 11:10
About 7 years ago I changed the engine in OEV7P my early car, as some of you will know it was making a tapping noise at Billing this year. I stripped the head and found one of the buckets had broken up, I changed it but as usual it was an oiling problem. Instead of stripping it I decided to re build the original engine. After a full rebuild the original engine is back in the car and running sweet.I spent a lot of time on the body work last winter but I am now happy with the cars overall condition.I have been trying to get it back on the road for the 40th anniversary run. The car will be there.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
laney
Postby laney » 01 Sep 2014 18:43
Hope you make it Chris, If there's one place for that car this is it... And You...[:D]
Postby Chris Turner » 05 Sep 2014 15:00
Thanks Alan, its all change, I will be on the run, hopefully we can see a few TR7s older than mine.
THE Coca Cola car
TR7 Sprint SJW 539S
John Wood
Postby John Wood » 06 Sep 2014 06:18
There will be 3 or 4 P reg cars on the run Chris but I think ACG97 will be the oldest. Great news you can now make it.
TR7 Sprint & TR8
Postby Chris Turner » 06 Sep 2014 09:42
Once the run and the NEC are out of the way I will be making a start on ACL20.
THE Coca Cola car
TR7 Sprint SJW 539S
John Wood
Postby John Wood » 06 Sep 2014 15:31
Is that a September 74 build Chris?
TR7 Sprint & TR8
JavaSe7en
Postby JavaSe7en » 10 Sep 2014 06:54
Hello Chris, could you elaborate on the â€￾tapping noiseâ€￾ issue?
My car has developed, over time, a tapping noise high up in the head. How did you recognize the broken up bucket, could you see cracks in the material?
Thanks in advance!
Ronald
Postby Chris Turner » 11 Sep 2014 21:57
Its a metallic tapping which is at engine speed, sounds a bit like a worn little end bearing but a bit sharper.
The worn bucket had a ring scored around its circumference on one and the top had come off the other.
Easy enough to change but the noise came back again so I assumed there was an oiling problem.
THE Coca Cola car
TR7 Sprint SJW 539S
Users browsing this forum: No registered users and 12 guests
