Original wipers
John Wood
Original wipers
Postby John Wood » 07 Aug 2014 19:30
Paddocks are out of stock. Does anyone else have them?
TR7 Sprint & TR8
Postby REPLIC8 » 07 Aug 2014 20:58
I would think your best bet is a used set from someone like S & S, a quick rub down and re-spray, then some new rubber blades and you're good to go. The original wipers certainly work better than any of the replacement stuff. Have you also tried rain-x on your screen?
1981 TR7 FHC
Roy Hankins
Postby Roy Hankins » 07 Aug 2014 21:10
Never seem to have much trouble picking up original wiper blades at the autojumbles.
I'll pick some up for you John at Beaulieu.
TR7 Coupe KDU 366N
TR7 Sprint ARW 181S
John Wood
Postby John Wood » 08 Aug 2014 06:29
When is Beaulieu?
TR7 Sprint & TR8
birminghamtr7
Postby birminghamtr7 » 08 Aug 2014 06:59
john speak to jim Johnson he found someone that had both sizes. but you'll have to be a bit patient and youll have to push as it sounds like he has a lot of gear.
Postby FI Spyder » 08 Aug 2014 13:24
I painted the original wipers on the Spider with auto trim paint after preparing the surface. I then replaced the rubber with new, I use brand name rubber like Trico. Still looks like new going on 7 years. I do this for all my cars following finding out the wipers for my Toyota was $157 (no longer available).
sonscar
Postby sonscar » 08 Aug 2014 16:09
I got some wipers from Robsport who were apologetic that they only had the pin fittings in 17 inch size.I bought two fitted them and they seem perfectly good.Steve..
Postby bmcecosse » 10 Aug 2014 16:55
16" blades work fine - Poundland! They have holes in for pin-fit. They may not last for ever - but they work! And yes - I use Rain X on the screen - it certainly helps. Allows just the intermittent wipe to be used in the heaviest rain!
Postby Beans » 10 Aug 2014 18:48
Same here as FI, I use refill's too.
Found out there is a slight difference between driver and passenger side, hence various brands ...
