Worst Job?
John Wood
Worst Job?
Postby John Wood » 30 Jul 2014 15:45
For me It's changing the window winder mechanism. Done one today, what a nightmare[}:)][}:)]
TR7 Sprint & TR8
Orange Rag
Postby Orange Rag » 30 Jul 2014 17:44
I agree with that one.
I changed the window track felts on the weekend which means removing the window. Seemed like an simple job but anything inside the door is a nightmare!
Not going to attempt the other door until I forget how much trouble it was, should take long at my age.
Orange Rag
Postby Orange Rag » 30 Jul 2014 17:49
Sorry, that should read "shouldn't take long" but I forgot what I was talking about!
whitenviro
Postby whitenviro » 30 Jul 2014 18:39
Really, the window regulator? I have done both sides twice and they aren't fun but not THAT bad. I think there is a trick to it, but I can't remember the details. I remember struggling with it, then suddenly they worked.
I had the worst time installing a new convertible top. That was no fun and I'm not too happy about how it looks.
[/img]
Postby Workshop Help » 30 Jul 2014 18:50
Window regulator? Not a big deal, maybe a moderate deal at best. I had no real problem with either side.
Mildred hargis
Postby tr8 » 30 Jul 2014 18:57
Try getting the power steering pump out of an A/C TR8, not fun....oopps TR7 section, sorry.
For the TR7 has to be changing the water pump.
Postby stevie_a » 30 Jul 2014 19:47
<font color="teal"><b>what about taking out the distributor on a 2.0L ?
sore knuckles are us.</b></font id="teal">
trekcarbonboy
Postby trekcarbonboy » 30 Jul 2014 20:02
Not sure if its the worst but replacing the block water drain plug is darn frustrating.
Craig '75 2.0 FHC
Postby busheytrader » 30 Jul 2014 21:21
Replacing the fuel tank closely followed by the remote gear change bushes......
Postby UKPhilTR7 » 30 Jul 2014 21:35
For me the window mechanism was ok on the passengers side. Bit lucky, but I was shocked at how well it all went in. Apart from that most of the jobs seem to be a pain, but the engine and gearbox out twice was a real pain. The job that I am not looking forward to soon though is the alignment of the doors. They were new ones and just do not sit right at all. Did the oil pump gauge recently, that was not bad at all.
Postby dursleyman » 30 Jul 2014 22:17
I have got a Rimmers kit to overhaul the windows, complete mechanisms, seals etc and you guys are putting me off the job. Never done a TR7 one but cut my arms to pieces on several other cars over the years. Why don't they make the access holes a bit bigger, or would that be too easy?
Postby FI Spyder » 31 Jul 2014 00:16
I've done the doors, stripped them out, took out quarter lite windows to disassemble and paint them, the job isn't that bad it's just a little fidley getting rollers in the guide. Worst job, changing the clutch. About the only thing I haven't done a water pump or head pull yet they're just too reliable.
Postby Hasbeen » 31 Jul 2014 00:38
I have done one in the 8, & one in the 7.
Refitting the 8 was a nightmare, as I did not have the mechanism at the right height for instillation.
The second one I just happened to have the stuff at the right spot, [about 3/4 up I think from memory] & it was a breeze.
Postby john 215 » 31 Jul 2014 04:57
Never had a problem with regulators, after the first dozen or so you sort of work it out [:p]
I think seized on heads had a few of those, pre head honcho days and trying to get decent door gaps on a door skinned off the car [V] very frustrating !
Postby andyf » 31 Jul 2014 05:57
I did a window regulator and can`t remember it being difficult but it was so long ago I might have just forgotten.
For me the worst job by far is cylinder head removal which I have attempted twice, once failing altogether and once managing it using lots of plus gas and brute force - nightmare job.
1980 Persian Aqua DHC
