ignition key won't turn
Sautie
Postby Sautie » 27 Jul 2014 06:58
My daughters' 7 has just experienced a problem. The ignition key goes all the way into the ignition and will only turn so far until it stops, roughly half through its turn. Result no electrical contact and thus unable to star the car.[:(]
Postby FI Spyder » 27 Jul 2014 08:48
Try some silicone spray (not graphite spray) and see if it's a lube issue. I believe they are made out of pot metal so can break. I had my glove box lock break so couldn't unlock the glove box.
dmtrmp6
Postby dmtrmp6 » 27 Jul 2014 12:28
Try rotating the steering wheel a small amount, if the lock bar in the steering lock is loaded with torque from the steering shaft it can be very difficult/impossible to rotate the key in the ignition lock - forcing the key may break either the key off in the lock or crack the lock housing. Rgds, Daryl M
Postby dursleyman » 27 Jul 2014 13:46
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dmtrmp6</i>
Agree with this, try "jiggling" the steering wheel back and forward gently as you turn the key. If that steering lock has engaged it can be quite difficult to free sometimes.
Sautie
Postby Sautie » 28 Jul 2014 07:40
Many t[:D]hanks the Silicone spray did the trick straight off.
