Starter repair
Starter repair
Postby bmcecosse » 12 Jul 2014 10:49
Does anyone have a link to a 'how to' repairing the starter? I have two failed starters - both just 'clicking' the solenoid but not engaging the motor..... and the one on the car right now is making a 'funny noise'......
Postby Cobber » 12 Jul 2014 13:08
It sounds like the contact in the starter solenoid is buggered.
You need to remove the solenoid from the starter and open the solenoid. You may need to use a soldering iron to melt the solder on the connection of the end cap to do this.
The end cap will be a copper contact that the solenoid when energized pushes against the terminals, thus completing the circuit and directing the power to the starter motor itself.
You replace this contact and the end cap (they come in a kit) and reassemble the solenoid and starter.
'98 MG-F, 69'Ford F250.
Postby bmcecosse » 12 Jul 2014 14:53
Yes - that's the idea! I was hoping for a 'HOW TO' video or at least a write-up. And a source of the 'kit' ?
Postby Cobber » 13 Jul 2014 01:56
Can't help with a video or a proper how to, as I've not had to do this for some years. The starter should be a Lucas 2M 100
Here's the kit.
http://www.ebay.co.uk/itm/STARTER-MOTOR-SOLENOID-CAP-TO-FITS-MANY-OLDER-LUCAS-2M100-3M100-/231137687516?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35d0e137dc
And here's a full starter repair kit (you may as well do the rest while your at it)
http://www.ebay.co.uk/itm/Lucas-2M100-3M100-starter-motor-Brush-bush-solenoid-contact-set-12v24v-volt-/251575867831?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a931719b7
jeffremj
Postby jeffremj » 13 Jul 2014 09:35
Yes - that's the idea! I was hoping for a 'HOW TO' video or at least a write-up. And a source of the 'kit' ?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Cobber has supplied most of the info you need. My addition is that the cap screws are usually covered with some sort of glue that has to be chipped out before you can remove the screws. Once this is done, a repair is straightforward - I have done a few in the 1980's and can only remember the 'glue' as a problem.
Postby bmcecosse » 14 Jul 2014 06:16
Thanks for the links! It's the 'soldering' that has me most worried I think - never my strongest suit.....
Postby Cobber » 14 Jul 2014 11:07
You can just get a replacement solenoid if your a bit shy of the soldering iron.
But how can you improve your skill set if you don't have ago?
Here's a tip, most people who have trouble soldering make the mistake of trying to use a piddly little soldering iron, these don't have the mass to retain sufficient heat to do the job of both melting the solder and heating the item to be soldered enough for the solder to bond with it.
Users browsing this forum: No registered users and 20 guests
