Heat from transmission
Sean Roth
Postby Sean Roth » 10 Jul 2014 02:25
I noticed that the center console and under the driver seat seems to get a little hot. I that normal?
SF Roth
sydney.wedgehead
Postby sydney.wedgehead » 10 Jul 2014 02:38
I've only noticed that when giving it at lot of WOT on extended highway runs.
Owen, aka:
- Marsu (570 posts, last dated 28 Nov 2011)
- omichaelshar (557 posts, last dated 17 Mar 2009)
Postby Hasbeen » 10 Jul 2014 03:46
The 8 has an aluminum sheet material stuck to the underside of the tunnel. It must have been getting very hot before this went on. Even with this the tunnel used to be quite hot to touch the carpet. You would not have held the gearstick long term, it was hot to hang on to.
I believe this was heat from the engine & exhaust, not the gearbox. After getting the engine to run satisfactorily cool, I have not noticed the tunnel getting hot.
Sean Roth
Postby Sean Roth » 10 Jul 2014 04:12
What is WOT?
SF Roth
Postby john 215 » 10 Jul 2014 04:47
WOT - <font color="red">W</font id="red">ide <font color="red">O</font id="red">pen <font color="red">T</font id="red">hrottle
My V8 gets warmish in that area the 4 cylinder don't seam too, you running a cat ?
Postby Workshop Help » 10 Jul 2014 15:19
Sean, my friend, yes it is normal for that area to get hot. The issue is the lack of an effective, if any at all, insulation on the underside of the transmission tunnel area. Then there's the small matter of the heat radiating up from the muffler and/or catalytic convertor. Those poor souls who drive with the steering wheel on the wrong side of the car miss out on this bun warming experience.
Postby busheytrader » 10 Jul 2014 20:09
You need a V8 in your life there Mildred. That'll keep both of your buns/bums warm! [:D]
