Water leaking from block
jfracer03
Postby jfracer03 » 25 May 2014 16:47
I have a 1980 TR7 that I've been working on and now that I've got it started there is water leaking from the engine block. Right above the water hose there is a rectangular hole that I was told is the weep hole, which is where the water is leaking out of. Do I have to replace the water pump or can I just replace the o-rings?
Postby FI Spyder » 25 May 2014 17:30
It's coming from a seal in the water pump. There is a water pump kit available for about $35. There is lots of posts about this so do a search and read up. There is a reverse thread bolt to remove, a procedure to get the correct gasket(s) to get the correct clearance of impeller to cover. Good idea to read up in OEM manual. Not something you should go into blindly.
Ron spent $600 on getting a new pump professionally installed in his son's coupe. A year or so later it was leaking a gain. Did it himself with a $35 kit. Job now done properly.
Postby Workshop Help » 25 May 2014 17:30
There will be those advocating repair of the old pump. There will also be those advocating replacement with a new pump. If you decide to go with the repair job, the knowledge learned from pulling and installing the repaired pump will be a benefit in another 6 weeks when the leak reappears. At that time you will become so enraged you will replace the leaking piece of junk with a new pump.
jfracer03
Postby jfracer03 » 26 May 2014 23:07
Where can I find that kit? I've searched around and can't find much.
Postby FI Spyder » 27 May 2014 02:41
Victoria British carry it as do British Parts North West.
whitenviro
Postby whitenviro » 27 May 2014 04:26
Changing the water pump isn't that difficult, but rebuilding your existing pump once you have it out may be problematic. I've tried to tear down two of them, with bad results. If you aren't properly equipped and very careful, you have a strong chance of breaking the impeller while trying to remove it from the pump shaft to do your rebuild. It is cast iron and brittle. In the end, a new pump isn't that expensive.
[/img]
Stag76
Postby Stag76 » 27 May 2014 07:05
For a bit more expense, you can fit an EWP, and forget about all the evils related to the mechanical pump.
Paul aka ChunkyChops has just fitted one.
http://www.ebay.com.au/itm/Davies-Craig ... 43ca3df77f
This is an Australian EBAY Listing.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
Postby DNK » 27 May 2014 11:41
I'm interested in the EWP
Just can't figure out how it is mounted
Stick a Wedge In It
Chunkychops
Postby Chunkychops » 27 May 2014 14:44
I refurbed my leaky pump with an ebay bought service kit but if its not done correctly, can cause further problems and expense. Have a look at this thread:
http://www.forum.triumphtr7.com/topic.a ... C_ID=19683
A new water pump will cost you about £240 but, as F1 Spyder says you must have the correct gasket thickness/clearance. Ive since fitted an EWP with controller and new kenlowe fan. Cost me the best part of £400 but well worth it.
Postby DNK » 27 May 2014 14:51
PICS PLEASE
Stick a Wedge In It
Chunkychops
Postby Chunkychops » 27 May 2014 19:39
Will put some pics up soon, the electric pump sits inline between the bottom rad hose and the block and is wired to a control unit in the cockpit which also turns the electric fan on and off when required via a relay.
You can set the temperature you want the car to run at and the controller does the rest. It will keep running for a couple of minutes after youve turned the ignition off to circulate the water preventing hot spots.
You need to re jig a couple of the coolant hoses and buy a blanking plug to block off the hole where the original pump sat. Theres a bit of faffing about and the expense but its worth doing if youre planning on keeping the car.
Postby Beans » 27 May 2014 20:23
Make sure the mating surface of the impellor is smooth when you rebuild it ...
Some more reading here http://tr7beans.blogspot.nl/search/label/Water%20pump
KFSullivan
Postby KFSullivan » 27 May 2014 21:39
+1 here. My son and I bought the kit. We got the pump out without too many problem because we borrowed a slide hammer that made quick work of it, but once the pump was out, the "fun" really began. We broke the first pump trying to get the impeller separated from the shaft, so then I bought a used pump from someone I knew out east. We re-built this one and fitted it, but only to find it was still leaking. Finally bought a new one from VB and installed it. No drips from the start, so in hindsight I should have just bought the new pump and called it a day.
Good luck!
1980 DHC Pagaent Blue
Stag76
Postby Stag76 » 28 May 2014 05:26
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I'm interested in the EWP
There are some pictures here that show the pump mounting.
http://s991.photobucket.com/user/stag76 ... t=3&page=1
TR7 Convertible
Sprint Motor
MegaSquirt EFI
Users browsing this forum: No registered users and 15 guests
