Removing old carpet adhesive
MikeRotherham
Postby MikeRotherham » 05 May 2014 19:18
I'm attempting to remove the old adhesive on the inner sill prior to fitting a new carpet.
Can't seem to shift the old adhesive. I've tried white spirit, cellulose thinners and even some Evo Stik adhesive remover.
Has anybody used anything that will soften the old adhesive enough to remove it?
Regards
Mike.
Postby FI Spyder » 05 May 2014 21:58
Lacquer thinner (toluene) is about aggressive as it gets, it will remove everything including the paint. Before going that route I would try some carpet glue remover, the kind that softens the glue that you glue household foam backed carpet to cement floors. I have some (lemon scented) that I used to remove said glue. It just softened it and I shaved it off using a rented industrial electric shaver (large exacto blade on steroids).
Neil_W
Postby Neil_W » 05 May 2014 22:03
Try a heat gun on the glue which will soften it then scrape off.
Alternatively use the wife's hair drier [:D]
Peter smith
Postby Peter smith » 06 May 2014 19:19
Just done mine last week, all you need is an old chisel and lots of elbow grease.
Postby dursleyman » 13 May 2014 16:33
Just doing mine now and its a horrible job. Found nothing really works except the elbow grease and I am finishing with a bit of petrol on an old cloth to get the last traces off.
Postby Hasbeen » 14 May 2014 00:55
I don't know you blokes, haven't you learned to recycle?
[:D] If it's that good, & stuck so well, I reckon you should just melt the top surface with a bit of petrol, & REUSE the stuff to sticl your new carpet down.[;)]
Peter smith
Postby Peter smith » 14 May 2014 18:01
Neil W
I think your car is the same colour as mine do you have the paint code so I can get some touch up paint?
Postby dursleyman » 15 May 2014 22:37
Yes, I wish I could re-use it as well but its got lots of jagged carpet fragments embedded in it from when the carpet was removed so it's not possible.
