Compatible AC parts???
Sean Roth
Postby Sean Roth » 07 Apr 2014 17:13
Any compatible part numbers that you all know of for the compressor? I am thinking of installing a Sanden unit.
Also, any compatible dryer?
SF Roth
Postby DNK » 07 Apr 2014 17:20
Did you try the search
Been quoted a few times.
If I had the info I'd send it
Stick a Wedge In It
HDRider
Postby HDRider » 07 Apr 2014 21:11
There are conversion mounts to use for a modern Sanden compressor on an existing York mount, mostly because classic Mustangs used similar units.
You are going to need replacment hoses for at least two of the 4 hoses and I strongly sugest replacing them all.
Who ever you get the compressor from should be able to help you with the dryer. Most of the fittings are 3/8" flare on the existing stuff. I think that the exception is the line from the compressor to the firewall and perhaps the compressor to the condensor.
Edward Hamer
Petaluma CA
Sean Roth
Postby Sean Roth » 07 Apr 2014 21:43
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by HDRider</i>
Edward Hamer
Petaluma CA
Any idea which model number of Sanden compressor?
SF Roth
HDRider
Postby HDRider » 08 Apr 2014 14:01
Sanden #508 I believe.
Edward Hamer
petaluma CA
tr7sprint1
Postby tr7sprint1 » 08 Apr 2014 16:37
Try this link for even more info:
http://nostalgicac.com/british-ac-compl ... ounts.html
Sean Roth
Postby Sean Roth » 09 Apr 2014 00:10
Any compatible dryer that you know of?
SF Roth
HDRider
Postby HDRider » 09 Apr 2014 13:43
I purchase one from Napa Auto parts a while ago. The part number is TEM 208631.
I think that the only difference is that the sensor port is on the motor side rather than than the bulkhead side. The sensor has enough slack to reach though.
Edward Hamer
Petaluma CA
