Preparing to pull the intake manifold off !
auto_cran
Postby auto_cran » 24 Mar 2014 23:59
So I'm finally getting ready to pull the intake manifold off the TR7 to cure the coolant leak (time and parts are now on hand). Prior posts make us think the o-rings are the culprit.
In the Members Blog, Mildred provided some help tips and the beloved Search button has been helpful (finding great tips from Beans and others).
I've got my manuals handy and I'm gonna takes some pics.
Question: is replacing the intake manifold gasket a must? I bought a couple assuming that I would replace it, but just want to confirm. And if so, should a gasket sealant be used?
Some tips so far:
Don't remove the choke/throttle cables
Don't remove the intake completely off - just set it to the side
Apply some silicone sealant to hold the o-rings in place.
Any other tips? This is my first big dive into the TR7 - and am very excited....(but want to get it right).
Thanks!
Chris
(auto_cran)
Neil_W
Postby Neil_W » 25 Mar 2014 03:59
<b><font color="red">To get to the o-ring on the back of the inlet manifold you will need to pull the manifold quite away out so no doubt the manifold gasket will break so Yes replace.</font id="red"></b>
<font color="red"><b>I used a thin skim of sealant to hold the gasket onto the cylinderhead or it can slide about - so I would put a bit on</b></font id="red">
Some tips so far:
Don't remove the choke/throttle cables - <font color="red"><b>No</b></font id="red">
<font color="red"><b>I would take the inlet manifold off to make sure all the faces are clean. The best way I found was to unbolt the flexible carb mouts ( 4 nuts each but are small & fiddly ).The carbs will be held together by the top cross piece & use a pilow or other to stop the carbs falling back to the suspension turret.</b></font id="red">
<b><font color="red">A small amount</font id="red"></b>
<b><font color="red"><b><font color="red">The hardest part is getting the 6 screws on to reattach the manifold to the cylinderhead as they have to pass through the gasket so taking the carbs off the flex mounting reduces the weight. Also the pipe under the inlet manifold can be a pain to get on as it is an olive connection / rubber pipes etc.
Use new screws to fix the Inlet manifold on & don't overtighten the screws into the alloy head.Sizes are UNF or UNC so watch them. Sizes are also in the works manual.</font id="red"></b>
Best to look at the Works Manual & print it off - better than Mr.Haynes so see below </b></font id="red">
Go to PDF Files on left hand side & download a Manual.
www.tr7.co.uk or http://www.tr7.co.uk/tr7-pdfs-various/1 ... anual.html
Postby dursleyman » 25 Mar 2014 10:26
A useful trick I found on here ( by jclay ) is to use a couple of temporary studs to keep the manifold in place whilst you fit the bolts. This stops it slipping down.
You can easily make them yourself by cutting the heads off some spare bolts and cutting a screwdriver slot in the end. Put one of the studs at each end and then you can concentrate on lining up the bypass pipe. The studs will keep the manifold located for you. When you have some bolts installed you can unscrew the temp studs and swap them for bolts. Easy!
Have a look here
http://www.jclay.me/jclay/Triumph_TR-7.html#9
http://www.jclay.me/jclay/Triumph_TR-7.html#10
1980 TR7 Sprint DHC
Postby FI Spyder » 25 Mar 2014 12:50
Theoretically gaskets don't need anything additional if both side are even (the gasket takes up any small variations).
For most gaskets I like to use a spray on (aerosol can) or red tacky gasket. This applies a smooth even amount. It is applied to weak side. For instance in the case of the valve cover it would be the valve cover side (not the head side). Not really a weak side for the inlet manifold but would apply it to that side anyway. It holds the gasket in place while assembling and allows relatively easy removal next time it's taken off as only one side is "stuck".
Postby jclay (RIP 2018) » 25 Mar 2014 13:10
<font color="red"><b>I used a thin skim of sealant to hold the gasket onto the cylinder head or it can slide about - so I would put a bit on</b></font id="red">
<b><font color="green">Check my website about studs as Russ suggested!</font id="green"></b>
Some tips so far:
<b><font color="green">(I would say yes, do remove them along with the fuel line and vacuum lines to distributor and brakes.)</font id="green"></b>
<b><font color="green">(DO NOT REMOVE THE CARBS! Remove the whole intake assembly as a unit. Requires two people and a rope. Remove top two bolts holding manifold to head and replace with slotted studs. Tie rope to carbs/manifold and have someone on the other side of the car hold it tight. Remove the other four bolts and lift the unit straight off.)
<b><font color="green">(Three little dabs of super glue works great.)</font id="green"></b>
<b><font size="4"><font color="green">BIGGEST MISTAKE YOU CAN MAKE! The GASKET only goes on ONE WAY! Tab on gasket must cover extra hole in head.</font id="green"></font id="size4"></b>
Postby Beans » 25 Mar 2014 16:16
And a few more tips and pictures here;
http://tr7beans.blogspot.nl/search/label/Water%20pump
Neil_W
Postby Neil_W » 25 Mar 2014 16:31
Inlet manifold set screws are 5/16 UNC - making a few is a good idea.
You can gauge the length by below & shows the gasket the wrong way round
http://www.ebay.co.uk/itm/TRIUMPH-TR7-I ... 0389512004
If you are on your own as I was when doing the job - reducing the weight of the inlet manifold is the safest way but takes longer but you'll learn a bit more of how things go around the carbs [:D]
auto_cran
Postby auto_cran » 25 Mar 2014 18:09
Thanks for all the replies and tips! What a wealth of good information!
OK, gonna go to the hardware store and pick up some 5/16" UNC screws, remove the heads and slot them so a screwdriver can be used on them.
Plan is for me to tackle the water leak this Friday. Will keep you posted!
Chris
(auto_cran)
Postby Workshop Help » 25 Mar 2014 21:41
Gee Whiz! Aren't we making a mountain out of a mole hill!
The five easily accessible manifold bolts are no problem. The front bolt will need a 1/4" ratchet with a long extension to reach the bolt head.
Remove the manifold with carburetors attached along with the choke and throttle cables as a complete unit, setting on a thick pad on top of the engine. Do not remove the cables.
The intake manifold gasket may come off intact. It did on mine the several times the manifold was removed. The gasket was successfully reused with no leaks.
Try and reuse the old bolts as new bolts from a typical hardware store are NOT the correct hardness grade. Brush them clean with a steel wire brush and apply a thin smear of grease to the threads to prevent corrosion.
Consider replacing the water pump at the same time as you will have done 85% of the work in getting to it. The 1976 models uses a 6 vane pump. The later 12 vane pump will work only if you also replace the pump cover.
Yes, as Jclay says, apply a drop or two of Super Glue to the new manifold O-Ring to hold it in place.
whitenviro
Postby whitenviro » 26 Mar 2014 23:43
That last hard to get to bolt is much easier with a u-joint ratchet extension. I would totally agree with jclay; disconnect the throttle, etc., but don't take off the carbs! Nothing but trouble there. The whole piece, carbs and all is not too big to handle by yourself.
[/img]
Bill Sales
Postby Bill Sales » 27 Mar 2014 06:25
Dont forget to check the condition of the bypass pipe between manifold and water pump and replace O rings. Had to remove manifold twice to replace bypass. Pipes corrode if anti freeze was not kept at correct level.
Bill Sales
auto_cran
Postby auto_cran » 27 Mar 2014 09:30
Thanks for the tooltip White.
Bill - yep, got a new bypass pipe and o-rings. Those were some of the parts I was waiting on.
And thanks to all for your input and ideas. What a good group on here.
Will report my progress soon.
Chris
(auto_cran)
Postby Beans » 27 Mar 2014 18:27
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by whitenviro</i>
... but don't take off the carbs! ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If you have read my blog you'll see that I prefer to remove the carbs.
Not much extra work, and it makes mating up the manifold to the engine so much easier.
So well worth the effort [;)]
Neil_W
Postby Neil_W » 27 Mar 2014 23:29
Originally posted by Beans[/i]
... but don't take off the carbs! ... If you have read my blog you'll see that I prefer to remove the carbs.
Second that [^]
auto_cran
Postby auto_cran » 01 Apr 2014 01:02
Just a quick thanks to everyone for their input. Over the weekend I managaed to pull the intake manifold and fix the water leak. It was a success!
Fairly straightforward - but I did run into a glitch. For details, check out my lengthy post in the Members Blog section.
Thanks again!!
Chris
(auto_cran)
