Plan would probably be to use it with a dual controller to run the pump and my electric fan.
Anyone have any experience with this please?
1980 TR7 Sprint DHC
Stag76 wrote:does anyone know of a compact external mechanical pump that can be fitted, like the Essex V6 as used by Stag owners?[/quot
If you use an external mechanical pump, the problems with plumbing will probably be increased, as you will have to
plumb from the radiator to the pump, then to the inlet on the existing pump cover. You also have to mount the pump and
fit a belt to drive it.
With the EWP, you fit it into the bottom hose between the radiator and pump cover inlet.
An external mechanical pump won't have the temperature control and power saving benefits of an EWP.
The plumbing and wiring to fit an EWP are not really a problem when you consider the benefits.
Users browsing this forum: No registered users and 79 guests
