What brake fluid do you use??
Sean Roth
Postby Sean Roth » 27 Jan 2014 23:59
It seems like DOT3 meets the spec, should I use that?
SF Roth
Postby FI Spyder » 28 Jan 2014 00:33
DOT 3 is spec supplied. DOT 4 has higher boiling point and is a little more expensive. Doesn't much matter unless you're racing. I don't tend to use brakes much so I use DOT 3. They are compatible.
Sean Roth
Postby Sean Roth » 28 Jan 2014 00:41
Thanks
SF Roth
Postby john 215 » 28 Jan 2014 04:55
Hi Sean,
I use DOT 4, get it from work very cheap and even in the shops its more ready available as most modern car's use it.
g4zur
Postby g4zur » 28 Jan 2014 07:37
Hi Sean
A couple of months ago I changed my master cylinder as my servo was leaking. Replaced all fluid with dot4 very cheap I thought.
5 litres off Amazon for around £20.
Regards
Gareth.
G.P.Albrighton
