Where to buy brake caliper rebuild kit??
Sean Roth
Postby Sean Roth » 20 Jan 2014 22:12
Can anyone suggest a website to buy the front end brake caliper rebuild kit?
I live in the USA.
Thanks,
Sean
SF Roth
Postby FI Spyder » 20 Jan 2014 22:52
Either VB or British parts NW. BPNW usually gives you the option of brand name or OEM option. I prefer to go with these when ever possible.
http://www.bpnorthwest.com/triumph/tr7-tr8/brakes/caliper-kit-oem-midget-tr7-mini.html
Sean Roth
Postby Sean Roth » 20 Jan 2014 23:35
Thanks, did you ever use their kit? The photo does not show the small o-ring that connects the brake fluid transfer hole area....
SF Roth
TheWedgeShop
Postby TheWedgeShop » 21 Jan 2014 07:35
Sean Roth
Postby Sean Roth » 21 Jan 2014 12:17
What about the dime sized plastic o-ring that is needed for the fluid transfer hole? I don't see that in any of the product photos.
SF Roth
Postby FI Spyder » 21 Jan 2014 14:46
I rebuilt my calipers but can't recall if I got them from VB or BPNW as I've ordered from both. Not sure what part you are referring to. I didn't take the caliper apart (apparently not a good thing to do). I took the pistons out, cleaned them up, you want to make sure they aren't corroded/pitted where they contact the rubber seal, replace rubber. metal rings. Use red rubber grease on rubber so it doesn't abraid when refitting pistons.
TheWedgeShop
Postby TheWedgeShop » 21 Jan 2014 19:32
Our kit does come with it. Which is why it is a bit more money.
Sorry there was not a photo to address that. It has been fixed.
Thanks
Clint
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Sean Roth</i>
SF Roth
www.thewedgeshop.com
Sean Roth
Postby Sean Roth » 28 Jan 2014 00:20
I rebuilt my front calipers.
On the first unit I damaged the v-notch seal that goes on the end of the cylinder, where a dust boot would go I guess.
Should I be worried about that and just buy another rebuild kit to replace that or is that seal just a dust protector? I am thinking that only the inside seal, midway through the cylinder, is the one that seals the brake fluid inside.
Am I correct?
SF Roth
