Headlight mechanism link arm
moodyblue
Postby moodyblue » 18 Jan 2014 18:18
The link end with the rubber/metal bush has been very tight on all my wedges, that's before you even fit the screw. The manual I have doesn't say much about it and one of my alloy brackets had cracked at the thin part of screw hole. So why is it that tight when fitted in the slot as it's obviously putting more strain on the motor? and, How tight should the screw be?
THANKS.
Postby jclay (RIP 2018) » 19 Jan 2014 03:31
Click on illustrations to enlarge:
http://www.team.net/TR8/tr8cca/wedgelab/other/headlights/headlights.htm
moodyblue
Postby moodyblue » 19 Jan 2014 12:41
Thanks for the link but I can't get it to work, is it correct?
Postby jclay (RIP 2018) » 19 Jan 2014 14:08
Worked last night, not working today!
Postby dursleyman » 20 Jan 2014 13:10
Its back working again!
1980 TR7 Sprint DHC
moodyblue
Postby moodyblue » 20 Jan 2014 19:42
Thanks, not what I was looking for but that's a good link for electrical information.
Postby Maxwell » 20 Jan 2014 21:16
Hi - Send me a photo of the broken part and I might be able to locate a spare.
Maxwell [:D]
2.0 TR7 FHC \ Current
1.8 Mazda MX5 \ Current
moodyblue
Postby moodyblue » 21 Jan 2014 19:35
Hi Maxwell, thanks for the offer of a replacement bracket. I should have asked on here before, but I managed to locate one at Robsport. It was the alloy bracket that had cracked around the screw holding the link with the rubber bush, ref. pic above. I just don't want it to happen again so I'm trying to find out why it's such a tight fit and if it cracked because the screw was too tight or even too loose.
