dhc fuel filler
sonscar
dhc fuel filler
Postby sonscar » 19 Nov 2013 19:18
After removing the fuel filler and drilling out the screws holding the plastic hat in the hole I was left wondering where the water drains out of.Judging from the crud in the well it hasn't been draining anywhere.Thanks in advance Steve..
Postby Beans » 19 Nov 2013 19:44
Lower parts of the filler neck's mounting plate act as drain ...
It bolts to the underside of this flange ...
The drain holes easily get clogged with dirt/leaves/etc, so a regular clean with compressed air is highly recommended.
(make sure the dirt being blown out can't enter the tank ...)
sonscar
Postby sonscar » 19 Nov 2013 20:07
Thanks for the info and photo.The neck was sealed up with what looked like silicon sealer and the crossheads were severely mutilated so it looks like the well was permanently wet but surprisingly very little corrosion.Steve..
Neil_W
Postby Neil_W » 19 Nov 2013 21:09
Steve - need to go back to Spec Savers - as can't tell difference between Filler & Filter [|)]
frankman
Postby frankman » 23 Nov 2013 12:32
Hi Beens do you have an new Hose - Fuel Filler Pipe ??
Wher do you get this (if it's new) rimmer does not have it ...
Or is it from Water Cooler somewhere :-)
thanks for the Info
Hello from Switzerland
Frank
Postby Beans » 23 Nov 2013 15:57
Original hose and pipe, only cleaned it up a bit.
Postby busheytrader » 24 Nov 2013 06:41
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by frankman</i>
<font size="2">Hi Beens do you have an new Hose - Fuel Filler Pipe ??
thanks for the Info
Frank</font id="size2">
Frank, try Robsport or S and S in the UK for second hand parts.....
frankman
Postby frankman » 26 Nov 2013 18:05
@ Beans ...even Beans like - cleaned it up -looks like new..[8D]
hey thanks busheytrader I will ask there
Frank
