paint
paint
Postby nervousnewowner » 17 Sep 2013 18:44
ok, in the nearish future I hope to start doing some work on my car heading toward reinstating it to its original blue, but under bonnet/in boot/interior I want to do myself to save a few pennies and to get things actually moving.
these areas I will rattle can paint so wondering where the best place is if anywhere to get the best colour match. car should be taihiti blue if I remember rightly, will also be sourcing red carpets and a new headlining eventually too... any words of wisdom much appreciated....[:D]
project dhc being stripped sadly, but project fhc taking over... Dave...
the new project at birth, watch it evolve...I hope...
Benzo
Postby Benzo » 17 Sep 2013 19:00
What you would spend on rattle cans would probably buy a little compressor and cheap spray gun that you will have for the future then.
you will get a much better finish & control.
Currently back to Basics with my BMW V8 Engined Build.
Postby bmcecosse » 17 Sep 2013 21:18
Hellfrauds will make you up rattle cans to a specific colour - but not inexpensive. When you use them - be sure to 'rattle' them well, and warm them in a bucket of hot water before use.
Postby FI Spyder » 18 Sep 2013 00:21
I did my passenger door and looks OK, just some difference in texture. Hard to simulate thermoplastic acrylic (TPA) paint where they sprayed it on then heated it in an oven to give the smooth shine. Not cheap as I used 6 cans on it. I would rent/buy a gun and get some proper auto paint. Still a lot cheaper than a 5 to 7 thousand paint job.[:p]
Postby Chris Turner » 18 Sep 2013 06:16
Dave, I recently sprayed the inner wings on my Pageant blue car with an aerosol, it was only supposed to be a temporary job. I removed all the parts from the inner flitch panels and used a can from local car spares. Im pleased with the job and my keen eyed son Robert thought Id had it resprayed. The secret is in preparation and also make sure you shake the can well.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
Postby nervousnewowner » 18 Sep 2013 19:12
I do have a hvlp gun in the flat but it states more for uses other than a car but may give it a try, was after rattle cans to start the resurrection to blue that I could do bit at a time and get the outer sprayed by a garage, but I guess I could try getting some practise on the inner panels and then try a bootlid or something....... hmmmmm got me thinking now.......[:p]
kstrutt1
Postby kstrutt1 » 18 Sep 2013 20:39
I brush painted the engine compartment with cellulose, 3 coats then flatted back to a smooth finish.
