Upside down valve springs.
Bobbieslandy
Postby Bobbieslandy » 12 May 2010 20:23
I thought i'd post a pic of my head after i fitted the springs upside down. only valve springs 1 and 5 are the right way up and i I wouldn't want anyone to get it wrong!
Rob.
Postby Hasbeen » 12 May 2010 23:27
Rob, apart from aesthetics, the up side down springs won't really
matter, if you don't rev the thing hard.
The main reason for the variable wound spring, in valve springs is
to reduce the weight of the reciprocating part of the valve spring
This allows a slightly lighter spring to be used.
The upside down spring will start to valve bounce at a slightly
lower RPM, due to the greater weight bouncing up & down, as the
valves open & close. So it really doesn't matter, if like me, you
rarely go over 4,500 RPM.
Bobbieslandy
Postby Bobbieslandy » 13 May 2010 07:11
That's my thoughts exactly, nice to get it right though.
Postby Beans » 13 May 2010 19:17
And with a Sprint of course you'll have to rev the nuts out of it [:D]
Marko
Postby Marko » 13 May 2010 21:42
+1
Postby FI Spyder » 14 May 2010 01:03
It would bug me to no end even if I didn't ever reach 4,000 rpm. How hard can it be to reverse them?
Marko
Postby Marko » 14 May 2010 10:13
well , you can remove them in couple of seconds with a proper size socket ,
putting them back on take a valve compressor
Bobbieslandy
Postby Bobbieslandy » 14 May 2010 16:23
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">It would bug me to no end even if I didn't ever reach 4,000 rpm. How hard can it be to reverse them?
yup, no more than a minute i guess provided the cam and rocker assembly is off. It can take a lot longer if the collets decide to jump off somewhere! i'm the same though, imagine getting it dyno'd and getting 139.9999999bhp, I'd be thinking it was that damn valve spring (even if the valve spring had nothing to do with it).
I took this pic of my new valve springs showing them the right way up. i locked up the garage and sat down thinking that was one job i wouldn't have to do for a while when i noticed in the picture number 4 inlet valve spring was upside down. It was if the bugger was laughing at me so it didn't stay that way for long!
Users browsing this forum: No registered users and 144 guests
