fuel, rust, holes & tank not a good combination..
Postby gaz » 05 Apr 2010 11:59
just started my 7 this morning and as I checked the inline fuel filter it was blowing bubbles inside it almost like opening a fresh bottle of cola everytime I gave it some throttle,
took it for a quick drive down to the bottom of the road and back no problems got out of the car and............
"DON'T LIGHT A FAG"
it was p!$$!ng fuel all over my rear axle.
Was a good job I got that new tank from S&S the other week, problem is it's supposed to be going to the bodyshop tommorow fo a couple of bits to be sorted & then after the bodyshop it was going to have the new tank fitted.
I only needed two 5 min drives out of it [:(!][:(!]
I suppose it could have been worse it could have given way when i went to S&S, but what a time to go i had it all planed bodyshop, petrol tank,then all ready for it's next MOT 5th May............
does anyone think i could get away with patching it up with that amalganating tape plumbers use when they do bodge jobs just for the two 5 min trips either that or £50-£60 on a flat bed £[:(]£
Postby Shauniedawn » 05 Apr 2010 12:08
Petrol can between your legs with a pipe into it and through the window into the engine bay connected to the pump. Voila.
Shaun
Postby gaz » 05 Apr 2010 12:15
yeh thought about that one............a little problem i dont know how much fuel is left in my tank, at the moment i have the car ponting up my sloped drive so that it stops the leak as the hole/holes are at the front of the tank, so i need to at least temp, seal the tank or i'll spewing fuel up and down the road & if rod the plod gets behind me thats me buggered....
Postby Shauniedawn » 05 Apr 2010 12:43
Poke a hole in it and let it empty . . .
Shaun
Postby Beans » 05 Apr 2010 18:11
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by gaz</i>
... the two 5 min trips ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Or just tow it there ...
Postby FI Spyder » 05 Apr 2010 18:30
There is an epoxy mix that someone used to temp seal the tank pin holes (I think it might be the stuff used to temp fix small muffler holes) but you'db have to find a store open that carried it. Easier to get a tow, bite the tow bullet and be glad the fates didn't see fit to put a spark on the freshly release gas.
Postby nick » 05 Apr 2010 19:25
There is an epoxy that works very well on small holes. It will bond even when wet. I recently used it on two pin holes in my tank. I bought it at a car parts shop. It comes in a stick. You break off what you need and kneed it in your hand which mixes the two parts. Then stick it on the hole. It hardens and can be sanded. Great stuff. Can also patch muffler holes.
'79 TR7
Postby gaz » 05 Apr 2010 19:47
I don't think it would work on mine you could stick a pencil through one of them[:(]
looks like a jerry can between the legs[;)]
please no jokes about fire number three..............
Postby busheytrader » 05 Apr 2010 22:18
Glass fibre matting and resin might hold it for a few minutes but the flatbed lorry sounds like the safer bet.
If there's one hole now there are many others just waiting to set themselves free...........
Periwinkle
Postby Periwinkle » 06 Apr 2010 00:32
Gaz,
The stuff we used on an oil pan was a product called JB Weld Water and a pencil sized diameter hole was not a problem for it. Another product here is called Quick Steel..same result. Other posts described it correctly.
Good Luck
Sue
Postby stevie_a » 06 Apr 2010 06:36
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Periwinkle</i>
Gaz,
Another product here is called Quick Steel..same result. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
<font color="teal"><b>I have used this many times it should do the trick
I know it as mega metal but you can get it from halfords as</b></font id="teal">
[url="http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_187803_langId_-1_categoryId_165691"]<b></b><font color="red"><u>Araldite Plumbers Putty</u></font id="red">[/url]
click red text
<font color="teal"><b>tip on using it :</b></font id="teal">
<font size="6">.</font id="size6"> <font color="teal"><b>Make sure you dry the surface</b></font id="teal">
<font size="6">.</font id="size6"> <font color="teal"><b>wire brush any the area ( don't go to big or you will find more holes)</b></font id="teal">
<font size="5">.</font id="size5"> <font color="teal"><b>snap the stick in half and kneed together until one colour</b></font id="teal">
<font size="6">.</font id="size6"> <font color="teal"><b>wet your hands (this stops it sticking to your hands )</b></font id="teal">
<font size="6">.</font id="size6"><font color="teal"><b> put over hole and smooth out </b> </font id="teal">
<font size="6">.</font id="size6"> <font color="teal"><b>should take half an hour to cure
This should seal the tank for a week or five...</b>D]</font id="teal">[:D]
Postby gaz » 06 Apr 2010 11:12
well I drove with the fuel can by my feet luckly i was able to remove a grommet in the bulkhead and run my fuel pipe directly into the footwell
as when I pulled up traffic lights a police car pulled up beside me, just as well i ran the pipe through the bulkhead or there may been teltale signs.......[:D]
Postby gaz » 06 Apr 2010 16:23
thanks for all the advice guy's
and Stevie looks like youv'e bodged before[:D]
Postby stevie_a » 06 Apr 2010 18:06
<font color="teal"><b>I have indeed ...[:D]
I did'nt drive a TR7 as a daily in Scotland for five years
and not know how to bodge...[;)]</b></font id="teal">
Users browsing this forum: No registered users and 106 guests
