Inner window rubber felt seal????
zekow1
Postby zekow1 » 24 Mar 2010 16:20
Has anybody changed there inner window seal???
I can't find anybody that sells them??
I thought of using one from a similar car but decided to ask you guys first
[:D]
Postby FI Spyder » 24 Mar 2010 16:57
The inner window felt/seal is an integral part of the door card and can't be replaced as such. New door cards have a separate seal that is clipped on similar to (if not the same as, haven't compared that closely) the outside seal and as such once the door cards are replaced can themselves later be replaced. New door cards (at least the ones I got) are improved beyond this advantage by having the upper third of the door card with an aluminum backing preventing the upper rear card warping up and outwards (the reason I had to replace my otherwise like new door dards.
Henk
Postby Henk » 24 Mar 2010 22:28
I have old doorcards and the rubber strip is tacked with staples
i removed the old staples and tacked a good rubber from another board on.
Or do you mean the feltstrips were the glass slides trough?
I buyed them by triumph specialist.
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
zekow1
Postby zekow1 » 24 Mar 2010 23:12
Here is a picture of one of Jclays cars
The Item I am refering to is the rubber piece were the window and the door meet .
Not the triangle window
Hope this explains it better
Image[/URL]
Postby FI Spyder » 25 Mar 2010 18:14
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Henk</i>
Maybe mine were too. I don't know if I still have them, probably not. Truth be told I can't recall as they were warped up and out so needed replacing anyway. I thought they were glued on.
Zekow..still not sure which you mean now. There's the seal between the window (part that moves up and down) that we're talking about here or do you mean the part the window slides up and down in the quarter lite (triangular) windows (also mentioned). This is a felt strip the snaps into front window channel (part of quarter lite frame. These are available (I glued in mine with contact cement as they tend to fall out, especially the rear one.) My windows were really stiff to roll up and down so I replaced these, as well as inner and outer window seals as new (straight) door cards and flushed the old grease from window winders and regreased them. This freed up the window winding, don't know which helped most as I think all were contributing factors and I did them all at once.
zekow1
Postby zekow1 » 25 Mar 2010 20:10
I should have done this earlier.
Henk
Postby Henk » 25 Mar 2010 20:31
Yes thats what about we talk!
They are only supplied on new doorcards.
Henk
Postby FI Spyder » 26 Mar 2010 18:16
Rimmers has them (door cards) on their sale flyer for cheap. Quick go to their web site and order them as it is over on March 28. I just got a set for Yellow TCT (and a bunch of other stuff).
Postby Rich in Vancouver » 26 Mar 2010 23:57
I bought a black left-hand early door card from Rimmers sale for ten quid and was thrilled when I unwrapped the carefully wrapped box to find it was a factory original still in it's BL packaging. I just wish they had the right hand available as well!
And yes, it came with the seal.
Rich
Postby FI Spyder » 27 Mar 2010 01:53
Was it the new style with upper third reinforced with aluminum?
Postby Rich in Vancouver » 28 Mar 2010 02:24
No aluminum on this one.
It's identical to the original on my early car.
(The seal is stapled on by the way)
Rich
Users browsing this forum: No registered users and 103 guests
