led dash lights
timxs
led dash lights
Postby timxs » 21 Mar 2010 21:37
Hi just put these led bulbs into my dash.
The bigger bulbs are501 T10 W5W 5 SMD LED (Green) Dash Wedge Bulbs501 item number 220571105812. I only put 2 in but they are certainly bright enough. I can see the clocks great now.
The smaller bulbs are 10x T5 / 286 GREEN colour dashboard LED bulbs UK item number 120316876357. They also fit into the switch panel above the cold air vents. I managed to fit all of the bulbs with no problems at all, just a straight swap.
I thought I would need a few (that’s why I ordered 10), till I realised the smaller bulbs in the clocks are for ignition, brake warning etc, so I have ordered some red ones to go behind them. I did put a radio in at the same time and knocked a wire on the rheostat so the dash lights all went out. I did think for a few minutes I had really buggered the job up till I realised what I had done.
The item numbers are on ebay.co.uk. Just thought I would try the bulbs as they were cheap and it has worked a treat[:D]
Tim
bottomtop
Postby bottomtop » 21 Mar 2010 22:01
Its great that has worked out. However, I would be careful about using a LED to replace the lamp behind the "IGN" warning lens. I think the resistance of the bulb that is in use there has a role to play in making that circuit work correctly. Others on this forum may know more.
timxs
Postby timxs » 21 Mar 2010 22:25
thanks i will leave that one alone just to be sure.
tr7 wiring more like alchemy than auto electrics.
Postby Odd » 22 Mar 2010 11:56
Looks like you've found some useable LEDs there... What we've been using earlier is a high intensity 9 LED unit
(pictured in this thread: http://www.forum.triumphtr7.com/topic.a ... C_ID=11187 ) for the pod illumination.
And as said before:
NEVER put a LED in the IGN warning light position since that one usually needs to conduct in both directions...
Postby john » 27 Mar 2010 17:35
ive tried the smaller lights in the switch panel but have to say they are not as bright as the original lamps so i've no installed them
Postby stevie_a » 27 Mar 2010 17:49
<font color="teal"><b>This is my car's dash now</b></font id="teal">
Henk
Postby Henk » 27 Mar 2010 19:31
Not bad, are that white or blue leds?
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Postby stevie_a » 27 Mar 2010 22:19
<font color="teal"><b>Blue led's </b></font id="teal">
welshsteve
Postby welshsteve » 28 Mar 2010 16:20
Hey Steve those clocks look great mate, did you take the green caps out or leave them in?
If it's got tits or tyres then it's gonna cost ya!
Postby stevie_a » 28 Mar 2010 17:50
<font color="teal"><b>T10 bulbs just like odd but blue with green filters removed
this person is selling them on e-bay </b> </font id="teal"> [url="http://cgi.ebay.co.uk/2x-Blue-Bulb-T10-5-SMD-LED-Car-Parking-Turn-Lamp-12V_W0QQitemZ250604094398QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3a592b03be"]Image[/url]
<font color="teal"><b>As for abuve the radio i have these </b> </font id="teal">
Very Flexible
Very thin
and it has M3 sticky back so you can just stick it up under the dash
<font color="teal"><b>got it from maplin at £1,29 per 5cm length
when i was in the shop the assistant brought out 4 colours</b></font id="teal">
Bendder
Postby Bendder » 28 Mar 2010 19:08
I just got a short length of those. I was going to try them in the door card lights to see how they looked and also under the dash in the footwells. I got the red ones to try.
mark
1977 TR7 FHC
1978 TR7 FHC
1980 TR7 DHC
1980 Rover SD1 4.0L
Postby stevie_a » 28 Mar 2010 19:31
<font color="teal"><b>They are very good.
You will find you will only need one or two to light up the interior
as they are bright</b></font id="teal">
Bendder
Postby Bendder » 28 Mar 2010 23:19
I was planning on 3 in the side card lights. Yes you are right they are very bright. I am going with the red to match the red check and red carpet.
1977 TR7 FHC
1978 TR7 FHC
1980 TR7 DHC
1980 Rover SD1 4.0L
ObiRichKanobi
Postby ObiRichKanobi » 03 Jul 2010 21:20
I just wanted to chime in and say I did the swap this week. Really straight forward and a simple swap. Used the T10 (4 of them) for the dash, and the T5s for the turn signal indicator and lights above the switch panel. The turn signals can now actually be seen in full daylight, but the ones above the switch panel didn't do much. They're so bright now I might have to actually use the rheostat!
1980 TR7 Spider, Bosch Jetronics EFI.
Postby Rich in Vancouver » 05 Jul 2010 02:28
I just tried to order a set of the T5's from the E-Bay vendor and he is out of stock-Darn!
Users browsing this forum: No registered users and 106 guests
