oil leak from pulley
higgie
Postby higgie » 07 Mar 2010 17:02
Hello,
I have a very annoying small oil leak from the pulley, i have changed the oil seal but after a journey i have oil in the bay.
I check the oil regularly and all seems ok with the level.
Final question with the pulley off should i be able to see the oil thrower inside the timing cover? if not fitted do you think this could be the cause.
Thnaks for you suggestions Higgie
V8Wedgehead
Postby V8Wedgehead » 07 Mar 2010 17:21
4 cylinder or 8 cylinder?
Michael
"If it is broken then fix it....if it is not then make it faster!"
higgie
Postby higgie » 07 Mar 2010 17:48
Michael,
Sorry 4 cyl
Higgie
Postby FI Spyder » 07 Mar 2010 18:03
With the main pulley off you would not be able to see the oil thrower as the oil seal in the timing chain cover would block your view. This is the oil seal you changed wasn't it?
higgie
Postby higgie » 07 Mar 2010 18:52
I did change the oil seal so with it out would i have seen the oil thrower?
Postby Beans » 07 Mar 2010 19:17
Check the pulley for scoring, that's the usual culprit not the oil seal.
higgie
Postby higgie » 07 Mar 2010 20:19
I HAVE CHANGED THE PULLEY FOR A NEW ONE
Postby Beans » 07 Mar 2010 21:00
Welcome to British car ownership, they don't leak, they just mark their territory [:D]
B.t.w. you don't have to shout ...
Users browsing this forum: Google [Bot] and 103 guests
