wow this looks the business ACG7 !!!!!
birminghamtr7
Postby birminghamtr7 » 04 Mar 2010 12:07
wish i had the money [:(]
http://cgi.ebay.co.uk/1975-TRIUMPH-TR8- ... 2a052afa39
Postby Beans » 04 Mar 2010 16:42
But why coilovers at rear combined with springs on the trailing arms [?]
Postby FI Spyder » 04 Mar 2010 16:54
Cause when you're flying over bumps at 100mph you don't want to bottom out?[:)]
Postby Beans » 04 Mar 2010 16:56
In that case fit stiffer springs [:D]
Postby TR Tony » 04 Mar 2010 17:15
Wow! That's certainly an impressively built up car.
I note it is advertised as a TR8, which of course it is not - a TR7V8 maybe, but not a TR8.
And is it just me who thinks it is a great shame that such an early TR7, apparently a factory press car & arguably historically important in TR7 terms, has been converted into something so utterly different from original?
I am sorry but to my mind the investment in that car would have been better spent restoring it to as close to original as possible. After all, it is not that hard to find a decent FHC shell to convert to rally spec, but I doubt that ACG7 could ever be put back to original spec now - lowered floors, stitched in roll cage etc.
Nice car but shame about the loss of such an early example.
TR8 FHC EFI Factory development car Inca Yellow</font id="size1">
Postby nervousnewowner » 04 Mar 2010 17:42
tony.....when you get the yellow one? and are you up at stoneleigh this year? and agree with you about the car, i know its like the pot calling the kettle black you will say as mine will not be stock but its also not an historically important car, some limited edition models and the like should be kept as original as possible...
but would have the engine if he did change it back...........[:p] and did i see corsa power steering......... mmmmmmmm will that work..... i need to look under a few corsa bonnets.....
Postby TR Tony » 04 Mar 2010 17:45
Sadly can't make Stoneleigh this year, will be spending the weekend at a meeting for a charity I work for[:(]
I must have a word with them about the timing of future meetings ...
The yellow car is ACN01080, factory built fuel injection development car that I bought last summer but only recently back on the road after a major mechanical overhaul. Looking forward to bringing her to a few events this year[:)]
Steve-LPS-Thomas
Postby Steve-LPS-Thomas » 04 Mar 2010 18:06
Cannot remember exactly, isn't this ACG 6?
It's a fact that early cars often survive simply because of the fact that they were developed for competition. Not sure if this is the case here but it's survival now is ensured (unless it's totalled of course)... Angry looking beast!
<hr noshade size="1">
willywonka
Postby willywonka » 05 Mar 2010 07:11
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">[i] and did i see corsa power steering......... mmmmmmmm will that work..... i need to look under a few corsa bonnets.....
Dave.
The Corsa steering will work as it is used a lot in the Escort rally cars.
You wont find it under the bonnet though, it is mounted directly to the steering column inside of the car.
It can be found on the Corsa 'C' model, if you are in any scrapyards pick one up for me as well.
[:D]
All the Gear, no idea
Troy ODoherty
Postby Troy ODoherty » 05 Mar 2010 08:58
Hi Beans the Group 4 rules for rallying said that the spring position had to remain original. You were however allowed to add extra springs. This is what the Escorts did with there 5 link rear suspension. Usually the standard spring is replaced with a very soft spring that is of no real use other than to fullfill the rule requirments. Doesnt appear to be the case in this one.It apperars that it has been built to suit the rules in england but not a true historic rally car.
I have an article in a UK mag from just after they caned the rally program. It is an interview with the development engineer and he outlines some of the changes they had planned for the next season. Revised dash to move driver forward, coil over rear shocks, bigger brakes and 15" wheels to accomodate them and allow a better choice of tyres.
It does however sound like it would bring a smile to your face to drive that car.[:D]
Cheers Troy
Postby Beans » 05 Mar 2010 09:33
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Troy ODoherty</i>
... the Group 4 rules for rallying said that the spring position had to remain original. You were however allowed to add extra springs ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Sounds plausible indeed [;)] untill I read this in the cars description
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">fronts ... Rose jointed compression struts<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Judging from the picture of the front suspension he clearly doesn't know what compression struts are [}:)]
Nevertheless an interesting car which could be great fun indeed [:)]
Troy ODoherty
Postby Troy ODoherty » 05 Mar 2010 09:46
It Appears that the front sway bar has been replaced with tension rods or radious rods. cant tell what is being used as a sway bar.
Cheers Troy
John Wood
Postby John Wood » 05 Mar 2010 12:29
Steve, ACG6 is registered KDU367N and is sprint engined, I think it's for sale somewhere at the moment for around £15000.
I'm intrigued what the registration is for this car as it probably is in the same KDUxxxN batch.
1975 FHC
KDU483N
Steve-LPS-Thomas
Postby Steve-LPS-Thomas » 05 Mar 2010 13:23
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> it probably is in the same KDUxxxN batch<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Yes, that is what I was thinking... the above pic was taken at Stoneleigh 2007 when it was for sale at £7995.
regards Steve
V8Wedgehead
Postby V8Wedgehead » 05 Mar 2010 23:56
ACG6 registered KDU367N is now in the US and there was some effort in getting it into the Targa Newfoundland but as far as I know it has not. I love how a converted TR7 all of a sudden becomes a TR8 and when they are for sale typically are listed as TR8s and rarely a TR7V8 or "TR8 Conversion" which is nore correct. A VIN tells the whole story!
Michael
"If it is broken then fix it....if it is not then make it faster!"
Users browsing this forum: No registered users and 105 guests
