Rear Bumper Studs
marknotgeorge
Rear Bumper Studs
Postby marknotgeorge » 16 Nov 2009 21:43
The final bolt on my rear bumper finally gave in today, after months of giving it a few minutes of various forms of abuse before thinking 'sod that'. Procrastinate, me? I can't be ars*d...
Anyway, all but two of the mounting studs have either unscrewed, or broken away from the mounting plate. Is there any way into the bumper frame without cutting big holes in it?
Mark, Derby, UK.
http://www.marknotgeorge.co.uk
Red
Postby Red » 16 Nov 2009 22:16
Unfortunately not. It's all welded together.
Your best bet here would be to drill out whatever is left and then re-tap the holes in a bigger size (might as well go metric, easier to get studs then [:)]). There should be enough leeway to go a size bigger without having to enlarge the mounting holes.
Garry
1976 2.0 (soon to be 3.5!)FHC
http://reds-tr7.blogspot.com/
Postby FI Spyder » 17 Nov 2009 01:17
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Red</i>
Without going out and measuring my bumper mounting studs, I would say they are already metric. Only engine should be SAE. I have same problem of frozen/rusted bumber bolts/studs. Broke one off with air gun. I'm going to try Loctite Freeze and Release Spray, Aerokroil, Ship-2-Shore in that order when I get around to that chore. Will report. Right now busy rearrangeing garage of thirty years of accumulation to make more room and instal 220V sub panel for air compressor. Big Job.
