MGF Wheel Centres
ticklemeelmo
MGF Wheel Centres
Postby ticklemeelmo » 11 Nov 2009 16:10
Does anyone have MGF wheels that they managed to get centres for without MG or Rover written on them. I know they are 55mm in diameter. The problem with the MG ones is that they are domed so the stickers I bought will not lay flat on them. Must be able to buy something that will fit?
Postby stevie_a » 11 Nov 2009 17:46
<font color="maroon"><b>If you get the sticky ones that are a rubbery texture I got mine from an e_bay seller
That was making other brands and I sent an e-mail to him with the Triumph Laural
they are ok to go strait over the MG sign
My only regret is I didn't scratch off the red paint on the MG lettering
If you look very close you can see it threw them
but only in close up you cant see it normally
The last photo is with a large spot lamp shining on it so you see it more </b> </font id="maroon">
swifty
Postby swifty » 11 Nov 2009 18:06
On mine I prised out the MG sticker, filed the dome flat and glued the flat TRIUMPH sticker on - worked a treat
[img][IMG]http://i728.photobucket.com/albums/ww281/swiftstuff/InternetExplorerWallpaper.jpg[/img][/img]
Chubster
Postby Chubster » 11 Nov 2009 18:59
Got mine from Robsport.[8D][8]
ticklemeelmo
Postby ticklemeelmo » 12 Nov 2009 09:16
I called Robsport but they only had Rover ones. I like the look of your centres stevie_a. I found a supplier on ebay but he says that the stickers are not suitable for domed caps. Do you know the name of the ebayer who supplied yours?
Thanks[:)]
