TR7 Coup headlining
tr0078
TR7 Coup headlining
Postby tr0078 » 02 Nov 2009 03:03
Hi all,
I'm preparing to replace the headlining in my TR7 coupe with edrose full length sunroof. I have a new lining from Rimmers and the complete sunroof frame, but was wondering if anyone had any pictures of what the finished job is supposed to look like.... I simply can;t find any photos online for reference!
I'm pretty sure I know how it goes together, but would just appreciate if anyone could help me - just one or two pics of the sunroof from inside, showing in particular the relationship between headlining material and aluminium sunroof surround would be great.
Thankyou!
Brad
EntonoX
Postby EntonoX » 02 Nov 2009 08:36
I have a picture of that, i 'll reply it this evening.
TR7, ACG 2700L
Postby Beans » 02 Nov 2009 17:11
Is the sunroof original to the car?
If not, you'll also need stiffening profiles which are welded around the sunroof's aperture.
tr0078
Postby tr0078 » 06 Nov 2009 00:08
Hi all,
The sunroof is a genuine TR7 edrose unit, but not original to the car - (I removed a pretty poorly fitting pop-up unit and cut the hole larger to suit)
I imagine it would be pretty easy to fabricate a profile around the apeture (wasn't aware I would need these!) but again any photographs would help me!
my email is bvermont@era2000.com.au
Thanks,
Brad
Postby Beans » 06 Nov 2009 19:56
Have been looking in my piccie archive but none clear enough.
Next time when I am in the shed to work on the DHC I'll try not to forget to take a few piccies of a bare shell with original sunroof hole [:D]
Are you in a hurry ???
EntonoX
Postby EntonoX » 06 Nov 2009 20:55
Oops, forgot to reply to this topic [:D]
here the two photo`s i got from my car.
photo`s moved if needed mail me!
This is new headlining, with foam insulation between lining supports. it took i think 2 days to get to this result. Careful measuring and trying, etc. [:0]
TR7, ACG 2700L
tr0078
Postby tr0078 » 07 Nov 2009 02:26
Not a big hurry, thanks.
I think I'd be able to manage to stiffen the roof aperture by welding some narrow guage steel angles to the inside - I have a bead roller which I could probably use to get the shape right before fitting, and I can use the alumium sunroof frame as a guide. Shouldn't be too difficult in theory.
I can see how missing the structure here was causing my problem with the headlining fit - will let you know how I go
Thanks for the pics EnotonoX - not exaclt y what I was looking for but they should be a help all the same
Postby Beans » 12 Nov 2009 20:34
... Next time when I am in the shed to work on the DHC I'll try not to forget to take a few piccies of a bare shell with original sunroof hole <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
As promised ...
tr0078
Postby tr0078 » 14 Nov 2009 02:11
Thanks Beans - that's exactly what I needed. I'm still probably a week or so away from tackling it further, but will post some pics to show you how it turns out.
