Where Best to lift????
zekow1
Postby zekow1 » 05 Oct 2009 00:52
Hi Guys
I was wondering??where is the best location to place the floor jack??
If you are interested in lifting the car in the front middle???
Postby Rich in Vancouver » 05 Oct 2009 02:10
I lift under the center of the subframe at the front and under the diff at the rear.
Postby PeterTR7V8 » 05 Oct 2009 02:11
Subframe works for me. It's also a good test of it's metal to rust ratio. [:D]
Otherwise there are pegs underneath at each corner of the cabin section that indicate jacking points if you are just doing one corner at a time.
zekow1
Postby zekow1 » 05 Oct 2009 02:19
DO you guys Mean
dead center under the motor ,in the middle of the x?
If this is so?
would this not pressure the bushings ?
They only support the motor/instead it would support the car ?
Postby Rich in Vancouver » 05 Oct 2009 04:49
If you think of it the sprung entire weight of the front end of the car is supported by the subframe whenever the car is on the ground, so it's not all that different when the car is jacked up
I am always really leery of using sheet metal jacking points on old cars. The subframe is usually protected from corrosion by the automatic chassis oiling system found on most TR7s. [;)]
Rich
Postby saabfast » 05 Oct 2009 19:41
I use the subframe but put a timber pad between the jack cup and the subframe. I have never tested the rust to metal ratio and prefer to spread the load across it a bit and protect it from the lugs on some of the jack cups.
Saab 9000 2.3 FPT Auto
Postby Workshop Help » 05 Oct 2009 23:35
No, you Bozos have it all wrong! Here in the machine shed, we mystically levitate the car with the powers of the Cosmic Consciousness. Then we set it down on some cinder blocks left over from a tornado proof outhouse project. Why do you people always want to do it the hard way?
Postby FI Spyder » 06 Oct 2009 00:28
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by saabfast</i>
Exactly the same for me. I lost the ability to levitate with cosmic consciousness some time in the 60's. I think it was some bad "stuff" that was in circulation.
Postby silverseven » 06 Oct 2009 00:52
you peeps actually remember the 60's?????
Postby Rich in Vancouver » 06 Oct 2009 02:13
I don't remember last week.
zekow1
Postby zekow1 » 06 Oct 2009 22:25
used the wood it worked great, thank you.
Users browsing this forum: No registered users and 82 guests
