Dash cables???Alternator Dash Mystery
zekow1
Postby zekow1 » 25 Sep 2009 23:12
Hi guys
I am almost finished with th e rebuild.well my kind of rebuild nothing like what some of you are doing.
and I find myself with a small prblem.
The bottom cables :
air cond switch: Colors??
the cigarrete lighter???
and the dimmer.
I looked in all my books and the diagrams and I am too stupid to find it.
please take me out of my missery .
I spend most of my time looking for things instead of working in the car .
OH and I have several extra screws from somewhere????[:D]
ImageImageImageImage<font size="2"></font id="size2"><font face="Arial"></font id="Arial"><i></i><font color="red"></font id="red">
Postby FI Spyder » 26 Sep 2009 01:17
If by cables/colors you mean wiring here's a pict. The order is the reverse shown. Cig lighter on left, Dimmer, A/C on the right.
Extra screws are par for the course, if you didn't I'd say you were short some to begin with. Unless you take picts of every screw you remove and package them and label them like it was a religion.
zekow1
Postby zekow1 » 27 Sep 2009 02:27
Thanks man
You make it so easy.
zekow1
Postby zekow1 » 10 Oct 2009 19:38
<i><font color="purple"><font size="3">This is about dash cables Or better yet the dash
so I decided [:)]instead of opening a new subject ,
went ahead an added to this one.</font id="size3"></font id="purple"></i>
<font size="4"></font id="size4"><font color="navy"></font id="navy"><b></b>I just came from my electical mecanic or as I call him the mamamamamaagician.
I, We,have not been able to get the alternator to charghe even thought at the bench the unit would charge 14.5V and 110 amps.
he cheched the cables and figured that the problem was in the <font color="red"><font face="Impact"><u>center dash</u></font id="Impact"></font id="red">center dash????
You heard right the <font face="Arial"><font color="green"><font size="3">center Dash</font id="size3"></font id="green"></font id="Arial">
yep, we took out the dash and found that between the large connector and the bulb the power there was no opower.
Sooooooooooo
He welded a cable between the second stripe on the connector to the + at the mini bulb and it worked ,14.5V and 110 amps.
how about that.
<font color="red"><font size="3"><font face="Arial">The Dash</font id="Arial"></font id="size3"></font id="red">
WHO KNEW?????[:)]
Postby silverseven » 20 May 2012 09:31
Hi Zekow ....
(sorry to hijack your thread , but I have a question pertinent to your post)
My car has an intermittent alt/ign light problem , where the dash lights and gauges either don't work at all when you turn the key on, or cut out and/or come back to life when ever they feel like (makes relying on the car as a daily driver questionable at best)
I'm starting to feel my problem is not the alt (second rebuild) but maybe wire gremlins, and maybe similar to yours......
Any way you can describe exactly where on the dash or cluster your "magician" ran the new wire ? (you would not have a pic or two be change eh?)
Thanks
zekow1
Postby zekow1 » 20 May 2012 15:05
HI Ron
No problemo ,actually happy to be of Help.
I believe your problem is a faulty dash " mother board" craking problem.
They get old ,the plastic start to crack resulting in an intermediate connect ,disconnect problem where it is cracked.
I'm including the change we made in the mother board by welding a cable . This is what you were referring to.
But also look at the other pics . Take a look at yours and if you see a crack , make the connection. weld carefully . but if you have many cracks?? try to see if you can find a used one in better shape . Rimmer sometime ago had used ones for sale .
Keep us informed.
WIll I ever finish Started on 07 2008
Postby silverseven » 20 May 2012 19:13
thank you sir, those are fantastic pics!
zekow1
Postby zekow1 » 21 May 2012 14:48
Ron D name is Zeke tell us if you find d problem
