Socket?
bottomtop
Socket?
Postby bottomtop » 21 Sep 2009 00:51
Howdy all,
Does the brains trust know what size socket I need to get the steering wheel off? All I know is none of my sockets are large enough.
I want to do this when I get the car back from the auto-electrical wizard, to fit the replacement. Its the standard plastic looking wheel,three prong black.
Many thanks.
Postby Hasbeen » 21 Sep 2009 02:07
The book says 11/16", but does not say what.
I use a 1 1/8 UNF socket, which is slightly loose on the nut, & just
goes into the hole in the wheel, but works OK.
The book says 37 LBS FT, which is low for such a size. I use even
less, only about 15 LBS, as over tightening makes it too hard to get
the wheel off again.
Postby PeterTR7V8 » 21 Sep 2009 02:11
It isn't an exact fit but a 1 1/8 tube socket works for me. It is a bit loose so that probably means a 28mm will be a good fit.
TR7Aaron
Postby TR7Aaron » 21 Sep 2009 02:45
Loosen the nut but don't remove it - leave it on the last few threads. Grab the steering wheel and muscle it off - mine came off much easier than I think it should. Leaving the nut on there will stop the wheel from bashing you in the face when it comes loose.
Aaron
Postby PeterTR7V8 » 21 Sep 2009 02:52
Good tip Aaron. Looks like I've been putting my crash helmet on unnecessarily all this time! [:D]
There is always a better way.
bottomtop
Postby bottomtop » 21 Sep 2009 04:04
Thanks for the info - and the safety tips!
Postby Beans » 21 Sep 2009 09:28
... so that probably means a 28mm will be a good fit...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Make that 27mm and you're spot on [;)]
