Master Cylinder Res Cleaning Tips?
Postby Rich in Vancouver » 18 Sep 2009 04:49
Does anyone have any tips for cleaning the plastic brake master cylinder resevoir? This would apply to the W/S washer res and the early rad expansion tank as well. I am rebuilding a master for my 7 and the tank is grungy. The other tanks have dirt and rust stains and I would like to get them all looking better. I have tried running them through the dishwasher with little improvement. Any recommended cleaners?
Thanks,
Rich
Postby jclay (RIP 2018) » 18 Sep 2009 05:24
Rich,
Someone soaked them in bleach for a couple of days. It was posted about two years ago. Might try Oxyclean.
Postby Rich in Vancouver » 18 Sep 2009 05:37
I have been scrubbing the M/cyl with a soft toothbrush with simple green (sorry honey![B)]) with quite a bit of improvement but it didn't work on the other resevoirs. I will have to give the bleach a try.
Rich
Postby Hasbeen » 18 Sep 2009 05:51
In the dish washer, Rich.
When was the divorce, or are you still working on that, along with
cleaning the resevoir?
Postby busheytrader » 18 Sep 2009 10:33
Someone here recommended Miltons baby fluid a while back. The stuff used for sterilising babies' feed bottles.
I haven't tried it myself as I've got a metal header tank, fitted a new uprated m/cylinder which is still clean and as for the washer bottle, well the rest of the engine bay makes it look clean........ Bleach might be a touch too caustic?
Postby FI Spyder » 18 Sep 2009 21:27
I've soaked my master brake resevoir and washer bottle in bleach (and water) over the winter while the car was up on blocks for other projects. They turned out rather well.
