Aluminum fuel tank? Bumper lightening
cook11
Postby cook11 » 17 Sep 2009 14:41
Hey Guys I would like to fab up an aluminum fuel tank for my Tr7. My company has CNC sheet metal equipment so material, and equipment availability is not an issue. What I need are drawings or any ideas on how to properly fab one up? Also any ideas on lightening the bumpers up on these cars? Thanks!
Marko
Postby Marko » 17 Sep 2009 15:48
the biggest problem is price of raw material.
aluminum is 6 times more expensive than steel.
i wanted to make an aluminum copy of the fuel tank and gave up when i saw the raw stock.
you could save about 50% on the mass of fuel tank.
as for the bumpers, they could be done too.
if your company has cnc machinery than you probably have atleast one engieer employed it will be a cakewalk for him to do some number crunching on the thickness of the bumpers made of aluminum.
Postby john » 17 Sep 2009 15:59
Isnt the bumper on the drophead wieghted to stop scuttle shake !!!!
cook11
Postby cook11 » 17 Sep 2009 16:21
My sheetmetal shop has a large amount of .125" aluminum offcut sheets kept for projects. One of the guys here used to work at a custom fab shop that produced aluminum fuel tanks for specialty oil rig trucks. I certainly have given the aluminum bumper idea a thought or two. I may go that route, definite weight savings! I would also like to get rid of those damn pop up headlight as well! They are like lead bricks and they never work when you need them! I have been thinking about mounting some sort of fixed headlight setup? Any ideas?
Postby Underdog » 17 Sep 2009 16:34
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by john</i>
Yes they are. That's why I have a FHC bumper on mine. I cut some open areas in the face of it to further lighten. You can't tell once the cover is on and I'm not planing on runing into anything. I left the rear one stock since it's been rearended once already.[xx(]
Jim Underwood
Marko
Postby Marko » 17 Sep 2009 17:41
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by cook11</i>
oil rig trucks have square or cylindrical fuel tanks, not that difficult to fabricate, tr7 has a bit more complicated shape because its assimetrical ,and has that dent so the differential housing doesnt hit the fuel tank
Jolyon39
Postby Jolyon39 » 17 Sep 2009 21:44
You can buy Alloy tanks off the shelf from Triumph Rover Spares in South Australia.
Jolyon
Postby FI Spyder » 18 Sep 2009 03:26
You can leave off the bumper dampers if you have a DHC for a savings of 20 lbs. or so. I like the pop up headlights as they are so unique people give a second take. Never had a problem with them. (Keep your connections clean.) People have done fixed headlight treatments. Do a search on this forum using search tool. Lots of work though.
I would check and see if aluminum bumpers would adversely affect or even invalidate your insurance.
I've got a couple of brother-in-laws in your neck of the woods (Mill Woods).
Yoke
Postby Yoke » 18 Sep 2009 04:40
Cook if your getting an aluminum tank done see what it would cost to do one more, I'd be interested in one if the price was right.
Postby Rich in Vancouver » 18 Sep 2009 04:55
I would really like to see a TR7 with alloy bumpers, either polished or brushed. Imagine a dark car with polished aluminum bumpers!
I think an alloy tank would be a big project to save a few pounds. They aren't that heavy to start with. I do have to admit that if I had your facilities at hand I would be tempted though!
[:D]
Rich
Postby Odd » 18 Sep 2009 05:38
I personally would be interested in a larger capacity tank in my '8, be it steel or aluminium alloy...
I feel the oem one don't give the range I need/want
- since I need to fill up more than once a day when on a drive...
Anyone heard of such a beast, or done some thinking themselves?
Marko
Postby Marko » 18 Sep 2009 07:53
the only thing that worryes me with alu bumpers (at least front) is the crash safety in regular trafic, for racing too especialy rally( trees , lamp posts,...).
the alu bumper would have to be built to the same strength and stiffnes as the steel one.
Letter A
what worries me... the bumper connects the chassis legs so they dont split appart in an even of crash , if you check the original steel bumper you will see that the rear plate(the one with holes for mounting the bumper is thicker and profiled for stiffnes ( like an U section).
if the bumper fails in the crash the next thing stopping the "intruding object that you crashed into" would be subframe , and it is good 500mm behind the bumper. and that is if the object was mounted to the ground, SUV isnt mounted to the ground.
see what i mean,
green chassis legs, blue bumper, red subframe
there is a lot "empty space" behind the front bumper.
letter B
on the other hand on the rear the chassis legs are interconected with the boot floor and spare tire well, and its encased with the sides of the trunk( rear arches ). that part is solid enough by itself.
the properly made alu bumper would have to be designed to the same strength( not stiffnes) as the steel one.
Postby Wayne S » 18 Sep 2009 08:09
With the exception of the ally tank which will be good because it will be less prone from rotting inside out, the weight saving all sounds like a lot of hassle for a road car... Why dont you just buy a Caterham instead lol? [:D]
<b>2.0 Litre DHC Grinnall
Postby Beans » 18 Sep 2009 08:41
Cut the middle section from the front bumper and bolt that in place (lightened of course).
Or weld a tube (as used in roll cages) between the front end of the chassis legs.
Marko
Postby Marko » 18 Sep 2009 18:45
bingo...
i wanted to suggest to use thicker aluminum between the chassis legs, and the rest of the bumper can be thin, if you realy have money to burn, aluminum honeycomb in the hollow section of the bumper so it absorbs the impact.
Users browsing this forum: Google [Bot] and 48 guests
