I think I have overtightened a front brake caliper bleed value on my std TR7. As a result the bleed value spins and will not tighten. On extraction the bleed value threads look crushed/crossed. I inserted a new bleed value but it does not does not seal and fluid leaks when break pedal is pressed. On extraction the new bleed value also has crushed/crossed threads. I now worry I have damaged the threads in the caliper inself.
Any suggestions what I do next...?
standard 1981 DHC
