Reviving Door Handles
Postby FI Spyder » 14 Aug 2009 04:41
Earlier Mildred posted how to replace your loose knobs on your door handles with new generic knobs. If you want to be more of a Scotsman (compliment) you can repair them. First you warm the soft plastic of the knob with a hair dryer (heat gun too harsh). Then pry out the siver disc with two small screw drivers.
Now is a good time to lube them, I used some graphite. Then put a suitable sized socket under the backside of the handle and with a punch (I used both pointed and flat) hammer the rivet till there is little to no play in knob like this:
Then warm the knob with hair dryer again and press in the silver disc and it will snap back in:
If you were pretty careful the marks will be minimal and no worse than any 30 year old handle. I don't know how long they will last but should last as long as originals. Cost = $0.00.
Postby busheytrader » 15 Aug 2009 08:46
Our window winder handles were also fitted to the classic shape pre-BMW minis. Mini bits were always cheaper at dismantlers or breakers in the past. This might be changing as they're going the way of 7's - There's far fewer on the roads these days.
MCNX BFF
Postby MCNX BFF » 15 Aug 2009 16:31
As an aside, has anyone heard from Mildred lately? Haven't seen her around the forum. [:(]--Monica
----MH-----
Postby Underdog » 15 Aug 2009 18:11
She probably saw the video of me thrashing my LT77 5spd and is sitting with a cold towel on her forehead![:D]
Seriously, hope all is well with her.
Jim Underwood
