Header Tank Leak
Spectatohead
Header Tank Leak
Postby Spectatohead » 05 Aug 2009 07:36
I had a small leak on the header tank. It was on the seam under the clamp. It only leaked when the engine was hot and the system was pressurized. I took it to a local radiator shop and they soldered the seam and repainted the tank all nice and pretty. However, they must not have done a pressure check or even filled it with coolant because once I had it back in the car and filled it was leaking with a cold engine and no pressure. Upon further examination I found that it was now leaking from where the coolant level sensor hooks up. They apparently melted the seal here while they were soldering.
The question I have for our vast knowledge base is, How difficult is it to replace this seal? Is it the same part on both the TR7 and TR8? Victoria British shows a listing for the 7 but not the 8, I find it difficult to believe that they would be different. They call it a "coolant probe bush" and show it fits '80 and '81 TR7s. I was under the impression that the late model 7s used the same tank as the 8s.
As always any help and/or insight is greatly appreciated.
Jim Clark
'80 TR8
'97 Maxima 5spd
Postby Underdog » 05 Aug 2009 16:23
I checked in my trusty old TRF catalog which is mostly a reprint of the factory parts book. Shows the bush #C43221 as the same for FI TR8 and 79 onwards TR7.
Funny thing is, my car is an original 1980 carb car and has the coolant sensor. According to the parts book, it isn't supposed to be there. [?]
Postby FI Spyder » 05 Aug 2009 17:36
I believe they added the sensor around the time they moved the tank from the RH side to the LH side. My 1980 Spider has tank on left with sensor, my TCT '79 build date with tank on RH side does not.
V8Wedgehead
Postby V8Wedgehead » 05 Aug 2009 17:46
The seal is the same for the TR7/8. The TR8s with the excepiton of the coupes have the sensor. It is real simple to install too.
Michael
1980 TR8 FHC/Works Rally Project
Spectatohead
Postby Spectatohead » 06 Aug 2009 01:53
I found one locally for a couple bucks. I'm going out tomorrow to get it. They are on the other side of town, 30 miles each way. I'll probably spend more on fuel for the trip than the part. My car is a carbureted 1980 TR8 with out AC, VIN TPVDV8AT206077. The tank is on the right side. I'm going to try to pay attention to how other 8s are set up when I see them. It may have varied by something like who was working that station on the line that day. Who knows? Thanks for the responses.
Jim Clark
'80 TR8
'97 Maxima 5spd
Postby jclay (RIP 2018) » 06 Aug 2009 02:59
The Fiat Spiders use the same probe and seals.
Also, the retainer plate can be installed backwards, but it will not hold pressure that way, so make sure you have it on properly.
Postby Beans » 06 Aug 2009 19:49
... the retainer plate can be installed backwards ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Do I miss something here, or am I on the point of learning something new on TR7's (as I have never seen a retainer plate on a header tanks probe) [:I]
V8Wedgehead
Postby V8Wedgehead » 06 Aug 2009 20:04
I have never seen a retainer plate on the sensor either. All TR8s with the exception of the ACN00XX came with the TR7 plastic bottle but were replaced in a service bulletin and the fuel injected cars have the header tank mounted on the right side inner fender. The fuel injected cars is mounted on the alternator bracket. The fuel injected bracketry is different than the standard carbed TR8s which the carbed TR8 were also different from the TR7s.
Michael
Spectatohead
Postby Spectatohead » 06 Aug 2009 22:36
Mine did not have a retainer plate. It turns out the local source didn't actually have the right bush. The original works very much like a "Push/Pull Grommet and Plunger" type latch commonly used in computer equipment. Except in this case the Grommet doesn't have 4 legs and the Plunger is the Coolant Level Probe. The shop had to order it for me. Cheaper than VB's but I still made a 60 mile trip for nothing. I'm tempted to just take it back to the radiator shop and have them solder a plate over the hole. I'm not going to, but I was tempted.
Jim Clark
'80 TR8
'97 Maxima 5spd
