A Wedge Can Humble You, Too
Urchin
Postby Urchin » 29 Jun 2009 01:26
A couple of nights ago, I noticed the island's mechanic working late so I stopped to chat with him. Turns out he was trying to diagnose a starting problem on a 90's Ford Taurus. He couldn't get a reading on his coder. Pretending it was an LBC, Together, we tracked the problem back to a bad coil - one of those new coils that sends power to each plug independently. The mechanic noted with relief that this problem was fairly simple.
Two days later, on Saturday morning, it's time to the oil and filter on my Spider. I start the car to warm it up; it runs for 3 minutes and then just dies out and won't restart. I check the cap and rotor, check for a spark at the coil [yes], check the plugs [dry]. So why are the plugs dry after trying to start the car several times.
The TR-7 has died directly in front of the Land Rover, so now I must take the Corvair to the local garage and see if the mechanic is around. Knowing I had to come off the island in the TR-7 today, he comes by with a sigh.
He confirms the spark and notes the dry plugs. He tries a shot of starting ether and we have brief combustion. So now it's the fuel system.
I pull the line from the tank, at the bulkhead, and then then remove the in line fuel filter. It's not clogged when I blow through it, but I also note that there's no gas spurting out. so the mechanic checks the fuel line at the fuel pump. There's no gas there. We take a coffee cup, fill it with gas, and then stick the intake line to fuel pump into the cup. The car starts briefly. So now it's time to look at the gas tank and lines.
Although I don't have a working gas gauge, I do reset the trip odometer every time I fuel up. It read only 122 miles - so I should have lots of fuel left. We take a long fuel hose to try and blow air back into the tank. You can hear air blowing through, not gas bubbling.
I put in a couple of gallons of fuel and turn the key. After a few pumps the car starts right up. Oops!
Today, the car came off island in the pouring rain. The car then ran 100 miles in the storm without further incident.
Gotta love a car that's such fun to drive yet so easy to repair.
Jeff
Jeffrey Aronson
P.O. Box 90
Vinalhaven, ME 04863
USA
'80 TR-7 Spider
'66 Corvair Monza
www.landroverwriter.com
Postby jclay (RIP 2018) » 29 Jun 2009 01:40
It's not what you know, but knowing where to find it!!
Many years ago, I kept hearing this funny sound so I went out side to see what it was. My neighbor across the street had his son's Yamaha CAT he was trying to start. He would crank it several times and it would fire right up, rev to the limit and then just die.
I watched him for a couple of minutes then realize that when he cranked the bike, he leaned it to the left, the same side that the fuel cock was on. I went and got the gas can I used for my lawm mower and put a gallon of gas in his tank.
He cranked it up and it started. Reved to the limit, so I quickly turned it off. I adjusted the carb for him and we tried it again. He started it and it had a nice idle. He cruised down the street and I went back to bed!
Postby PeterTR7V8 » 29 Jun 2009 02:02
Get that gauge fixed!
Vinalhaven looks like a nice place if Google Earth is anything to go by.
Urchin
Postby Urchin » 29 Jun 2009 09:40
Vinalhaven is a fascinating island. Take a look at photos on my website, www.landroverwriter.com , or at the island's site, www.vinalhaven.org .
Raining again throughout the state this morning; the top stays up for this morning's run to a tractor parts place before taking the ferry home. Sadly, the TR-7 must remain at the ferry terminal on the mainland during the summer. While I will be driving it on 200 mile trips several times this summer, I will miss seeing it every day at home on the island (: .
Enjoy!
Jeff
Jeffrey Aronson
P.O. Box 90
USA
'80 TR-7 Spider
'66 Corvair Monza
Users browsing this forum: No registered users and 86 guests
