Tyres to suit 13" dia rims Width Ratio Rim L
Postby Cobber » 28 Jun 2009 01:58
<font size="2"><font face="Comic Sans MS">
OK due to the ongoing confusion about the availability of tyres to suit 13" dia rims here are some that I've found please feel free to add to the list.
These are available in Australia so for other countries check with your local distributor.
<hr noshade size="1">
<font size="3"><b>Goodyear: </b></font id="size3">
<u>GT3:</u> http://www.goodyear.com.au/TyreDetailAc ... m=3PerPage
175/70R13 82H
185/70R13 86H
<u>Ducaro GA:</u> http://www.goodyear.com.au/TyreDetailAc ... m=3PerPage
185/65R13 84H
<u>LS2000:</u> http://www.goodyear.com.au/TyreDetailAc ... m=nPerPage
175/70R13 82H
<u>Regatta Touring:</u> http://www.goodyear.com.au/TyreDetailAc ... m=nPerPage
175/70R13 82H
<font size="3"><b>Yokohama:</b></font id="size3"> http://www.yokohama.com.au/
<u>Y352:</u>
Item Description width series 205/60R13 86H Y352
rim LI/SS Pattern Overall:
Diameter mm: 578
Overall Width mm: 210
Optimum Rim Width: 6.0"
Min Rim: 5.5"
Max Rim: 8.0"
Revs per Km: 567
These are an excellent tyre!
http://www.yokohama.com.au/ourtyres/tyr ... tyreid=179
I'm led to believe these my also be available in 215/ 60R13 size
<font size="3"><b>Bridgestone:</b></font id="size3"> http://www.bridgestone.com.au/
<u>RE92:</u>
(P185/65R13)
Width mm: 185
Aspect ratio: 65
Rim dia: 13
Load rating: 83
Speed rating: H
Overall dia mm: 570
Australian Made!
(P205/65R13)
Width mm: 205
Aspect ratio: 65
Rim dia: 13
Load rating: 89
Speed rating: H
Overall dia mm: 596
Australian Made!
http://www.bridgestone.com.au/tyres/treads/re92.aspx
<font size="3"><b>Firestone:</b></font id="size3">
<u>Firestone TZ100:</u>
(185/65R13)
Width:............185
Aspect ratio:.....65
Rim dia":.........13
Load rating:......84
Speed rating:.....H
Overall dia mm:...572
http://www.bridgestone.com.au/tyres/treads/tz100.aspx
These Firestones are made in New Zealand I'm told.
Firestone is owned by Bridgestone.
<b><font size="3">Khumo:</font id="size3"></b> http://www.kumho.com.au/
<u>769:</u>
185/65 R13 84H........... RRP: A$139
205/60 R13 86H........... RRP: A$118
<font size="3"><b>Hankook:</b></font id="size3"> http://www.hankooktyre.com.au/Main/default.aspx
<u>Ventus HR:</u> II 185/60R13H
<u>Ventus V8:</u> RS 185/65R13V
<font size="3"><b>Toyo:</b></font id="size3"> http://www.toyo.com.au/Performance.htm
<u>Proxes RA1:</u> *205/60R13 86V
*185/60R13 80V
These are a street legal competition tyre. http://www.toyo.com.au/Proxes%20RA1.htm
<u>Proxes R888:</u>
185/60R13 80V
I 205/60R13 86H ("SG" tread compound)
205/60R13 86V
225/45R13 84V (don't know how you'd go fitting these)
Another street legal competition tyre http://www.toyo.com.au/Proxes%20R888.htm
<u>350:</u> 185/70R13 86T Note: these are only T rated!
<b><font size="3">Michelin:</font id="size3"></b> http://www.michelin.com.au/home/default.asp
<u>Energy XM1:</u> http://www.michelin.com.au/tyres/passen ... rgyXM1.asp
185/70R13
Load rating: 86
Speed rating: H
Min rim width: 4.5"
Optimum width size: 5.5"
Max rim width 6.0"
185/60R13
Load rating: 80
Speed rating: H
Min rim width: 5.0"
Max rim width 6.5"
<font size="3"><b>Federal Tyres:</b></font id="size3"> http://www.federaltyres.com.au/
<u>SS535:</u>
185/60R13
Load rating: 80
Speed rating: H
Min rim width: 4.0"
Optimum width size: 5.0"
Max rim width 6.0"
Overall dia mm: 552
<u>SS621:</u>
185/60R13
Load rating: 80
Speed rating: H
Min rim width: 5.0"
Max rim width 6.5"
Overall dia mm: 552
205/60R13
Load rating: 86
Speed rating: H
Min rim width: 4.5"
Optimum width size: 6.0"
Max rim width 6.5"
Overall dia mm: 576
<u>SS657:</u>
185/60R13
Load rating: 80
Speed rating: H
Min rim width: 5.0"
Max rim width 6.5"
Overall dia mm: 552
205/60R13
Load rating: 87
Speed rating: H
Min rim width: 6.0"
Max rim width 6.5"
Overall dia mm: 576
<u>SS731:</u>
185/79R13
Load rating: 86
Speed rating: H
Min rim width: 4.5"
Max rim width 6.0"
Overall dia mm: 576
<u>Formoza FD1:</u>
185/60R13
Load rating: 80
Speed rating: H
Min rim width: 4.0"
Max rim width 6.0"
Overall dia mm: 552
205/60R13
Load rating: 87
Speed rating: H
Min rim width: 4.5"
Max rim width 6.5"
Overall dia mm: 576
<u>595 drift Competition:</u> http://www.federaltyres.com.au/specs/ss595.pdf
185/60R13
Load rating: 80
Speed rating: H
Min rim width: 5.0"
Max rim width 6.0"
Overall dia mm: 552
205/60R13
Load rating: 87
Speed rating: H
Min rim width: 5.5"
Max rim width 6.0"
Overall dia mm: 576
<font size="3"><b>Continental:</b></font id="size3"> http://www.conti-online.com/generator/w ... ew-en.html
<u>ComfortContact-1:</u> http://www.conti-online.com/generator/w ... abNr=.html
175/70R13
Load rating: 82
Speed rating: H
Min rim width: 4.5"
Max rim width 6.0"
Overall dia mm: 586
<font size="3"><b>GT Radial: </b></font id="size3">http://www.tyres4u.com.au/brandselector_doc-gtprodpassenger2_img-gt_show.aspx
<u>Champiro GTX-65 </u> 185/65R13 High Performance 84H
<u>Champiro 70 </u> 185/70R13 Touring 86H
<u>Champiro 60 </u> 205/60R13 86H
<u>Champiro 728</u> 175/70R13 Touring 82H
<u>Champiro WTPlus</u> 175/70R13 Winter Tread (M+S) 82T
<font size="3"><b>Sumitomo:</b></font id="size3"> http://www.sumitomotire.com/
<u>Cyclone Radial GT: </u>185/70R13.
<u>HTR 4:</u> 205/60R13.
<u>HTR T4:</u> 175/70R13. 185/70R13.
<u>HTR 200:</u> 215/60R13. 205/60 R13. 195/60R13. 185/60R13. 175/70R13.
<u>SC 628:</u> P185/70R13.
I don't know how accurate this imfo is for the availability of the the sizes listed
<font size="3"><b>BF Goodrich:</b></font id="size3"> http://www.bfgoodrich.com.au/
<u>Sport T/A:</u> 185/70R13H
Here's a handy table from BF Goodrich for alternative sizes with + up sizing: http://www.bfgoodrich.com.au/index.php? ... ype=Street
<font size="3"><b>Nankang:</b></font id="size3"> http://www.nankangtyres.com.au/
<u>XR-611 Crossroader: </u>205/60R13 86H. 185/60R13 80H.
<u>CX-88 Tourer:</u> 185/70R13 86H. 175/70R13 82H.
<u>RX-615 Remex:</u> 205/60R13 86H. 185/60R13 80H. 185/70R13 86H. 175/70R13 82H.
</font id="Comic Sans MS"></font id="size2">
85'Alfa 90, 69'Ford F250.
Postby silverseven » 28 Jun 2009 03:55
nice, thanks for the info Cobber!
[8][8][8][8][8][8]
Postby Hasbeen » 28 Jun 2009 05:44
Hay, Cobber, according to my books, I'm supposed to have 185 70 R13s
on a 5 speed 7.
Most of those you've listed are lower.
May be you have better roads than we do, down there in the cold, but
I have tried lower profile tyres, up here, in the bush, & don't like
them at all.
On a billiard table smooth road, the 8, with it's low profile tyres,
& stiffer suspension is great. However, out here, I go round many
cormers faster in the 7 as it's stock springs, & tyres can absorb
the lumps, & waves in the road, without being thrown off line so
much.
Postby Cobber » 28 Jun 2009 06:28
I've added some 70 series tyres more to come!
MillerScottLite
Postby MillerScottLite » 28 Jun 2009 13:39
I have some Sumitomo HTR 200 205/60's with no issues and I love them. They were about $45 each.
Scott
