Hazards work, indicators don't
John Wood
Postby John Wood » 25 Jun 2009 21:17
Any ideas please?
1975 FHC
KDU483N
Postby FI Spyder » 26 Jun 2009 00:45
Hazard and turn signals use different units. Turn signal unit may be faulty, bad connection in horn/turn/dip switch.
Postby jclay (RIP 2018) » 26 Jun 2009 04:14
Hazard flasher unit is by the fuse panel.
Indicator flasher is up under the dash on the door side.
HowardB
Postby HowardB » 26 Jun 2009 06:48
The flasher unit has a reputation for flashing v slowly or not at all and is often replaced by an electronic flasher available from Halfords. The unit is the same size and only modification required is an additional earth connection.
John Wood
Postby John Wood » 28 Jun 2009 13:54
There is no unit under the dash, just 2 loose connections.
1975 FHC
KDU483N
John Wood
Postby John Wood » 28 Jun 2009 14:18
All sorted now
1975 FHC
KDU483N
Postby jclay (RIP 2018) » 28 Jun 2009 15:08
Kewl! Now you are a regular flasher!
pupinabox
Postby pupinabox » 29 Jun 2009 20:10
what did u do?
Users browsing this forum: No registered users and 98 guests
