Cooling system / thermostat
Postby andyf » 16 Jun 2009 08:24
Following on from my dodgy garage post a few weeks ago ref my front fog lamp wiring, the main reason I took it into the garage was to drill out and re-tap my thermostat housing (the bolts snapped off when replacing the thermostat).
When I received the invoice, they had charged for a new thermostat which I did not ask them for. After grilling them, they insist that the new stat they put in was the correct one, but I now have my doubts.
The car runs at the correct temperature for a few days, then the gauge will rise quickly to about 3/4, then fluctuate, dropping back to below 1/2, then rising again. Upon checking, the water level has dropped and I top up, and away we go. I wrote off the first few times as an air lock, but it has now done it about half a dozen times in about 5-6 weeks. Could this be caused by the incorrect thermostat without the "foot" or could it be something else?
I can also see no evidence of coolant leaks, although as it happens when driving it could of course be coming out of the overflow.
1980 persian aqua DHC
Postby Beans » 16 Jun 2009 11:06
Could be the thermostat being incorrect.
Just take it out and check it has the foot plate, air bleed valve and has the correct opening temperature (should be 88ºC).
Postby bmcecosse » 16 Jun 2009 15:19
And feed the overflow pipe from the tank into a catch bottle - to see if any fluid escapes. But it would only do so if the pressure rose high enough to lift the cap release valve.
Postby stevie_a » 16 Jun 2009 17:41
<font color="maroon"><b>I have been told that my problem with my temperature dropping
could be to do with getting an air lock in the system
and as good way to get rid of this is to drill a hole in the thermostat housing
and tap it then insert a grub screw as it is the highest point in the engine
the air would escape and eliminate air locks
do you think this would work?
after all most modern cars have somthing like this fitted
you could also rig up some way to take a good temperature reading from this point </b> </font id="maroon">
Postby Beans » 16 Jun 2009 21:56
Air shouldn't be a problem if the system is filled correctly AND the thermostat has a (small) air valve.
Postby stevie_a » 16 Jun 2009 22:01
AND the thermostat has a (small) air valve.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
<font color="maroon"><b>can you explain this one ...Image</b> </font id="maroon">
Postby bmcecosse » 16 Jun 2009 22:13
It should have a little 'jiggle pin' in the top. My car clears air into the expansion tank ok - without that extra tapping. But if in doubt - warm it up, switch off - then squeeze the top hose to push water (and any air) into the expansion tank.
Postby stevie_a » 22 Jun 2009 14:49
<font color="maroon"><b>New thermostat fitted </b> </font id="maroon">
<b>then squeeze the top hose to push water (and any air) into the expansion tank</b>.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
<font color="maroon"><b>With expansion tank cap on or off???</b></font id="maroon">
Postby Beans » 22 Jun 2009 16:26
You'll have to take the cap of to check if and how much the coolant level has dropped (with cool engine of course).
As for the "jiggle pin" as BMC calls it, you should be able to hear it if it's there. If you squeeze the top hose you will hear a light ticking sound coming from inside the thermostat housing.
jbsjim
Postby jbsjim » 22 Jun 2009 17:14
I'm looking for a source for the correct thermostat for the 80 FI engine - preferably a US source. I bought one from Victoria British and it does not have the relief valve and has been giving me trouble with trapped air. Can anyone help?
Thanks! Jim
Postby FI Spyder » 22 Jun 2009 20:24
Rockauto.com has them in the States. I got mine from Robsport I believe but only after getting the wrong one and requesting one with the Triumph "foot". Thermostats are the same for all only the housing is different.
Here is what your looking for (rockauto picture):
Postby Beans » 22 Jun 2009 21:11
Air vent visible on the right hand side ...
Postby stevie_a » 22 Jun 2009 22:02
<font color="maroon"><b>The one i took out had that air vent but the new one did not
is this an issue??</b></font id="maroon">
Postby FI Spyder » 22 Jun 2009 22:09
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by stevie_a</i>
[maroon][b]The one i took out had that air vent but the new one did not
The air vent or "jiggle valve" allows air to get past the themostat so it is not trapped in the system. It could be an issue.
Postby busheytrader » 23 Jun 2009 08:50
Some people swear by drilling a 3mm (1/8") hole to replicate the jiggle pin bleed hole.
Whatever engine this applies to, refit the stat with the hole at the highest point.
Users browsing this forum: No registered users and 97 guests
