FHC RESTO
mak
Postby mak » 09 Aug 2009 20:48
Think you;re right, mines just bolted together with a gasket.
macmattom
Postby macmattom » 10 Aug 2009 00:03
<font face="Comic Sans MS"><font size="2"><font color="blue">Hi Paul. I'm doing a deep strip/rebuild on my 1977 FHC and have come up against a problem during my rebuild - in my naive stupidity of thinking I could remember where certain cables were connected from 2 1/2 years ago I now have a few "loose ends" (sorry for the awful pun [:o)]).
I was thinking that the wiring loom on your car <i>should</i> be the same as mine, as your FHC is also a 1977. As you have probably done a far better job of tagging your wires than I did, if I was to get some photos, might you consider advising me where or what the cables connect to? I'd really appreciate any help as I'm at a point where things are now being held up and I'm almost ready to go for launch.
Thanks for any help you could give me,
Mac
</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby RUDDY » 10 Aug 2009 11:00
Mac, I can't remember if I did tag anything, I do remember taking photos of wiring behind the dash and where it was running, I know for a fact that I haven't tagged anything in the engine bay because I will probably use the loom from the V8, I have a brand new boxed wiring loom which I may modify once I see what modifications the V8 loom needs.
cheers, Paul
Postby RUDDY » 15 Aug 2009 19:15
Dry run, parts just laid in place, bit of dressing up to do for accurate fit and a few small invisible repairs to do while I can get at them before the 'panels' go on, fire up the spot welder next week.
Postby Beans » 15 Aug 2009 22:36
Looks like a proper job you're doing [;)]
Postby PeterTR7V8 » 16 Aug 2009 06:55
Good to see such effort going into car.
Postby RUDDY » 19 Aug 2009 14:08
Still playing with the panels, sorting out the gaps, tried on the front wing, have a feeling I am trying to achieve a tightness of gap that the factory never did, anyway aiming for a nice even gap around the door. The wing has to come back off to replace the front inner tub.
cheers, Paul
Postby Beans » 19 Aug 2009 20:32
Can only quote Hasbeen here ...
Pitty about those door-shut-lines. You've just blown any chance you
may have had in concourse competitions. No body is ever going to
believe they were like that, when they left the factory. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
[:D] [:D] [:D]
