Clock fixes please!
seven
Re: Clock fixes please!
Postby seven » 03 Jul 2015 12:04
Dodge Dakota 4x4 '05
Triumph TR7 DHC '81
Triumph 2.5 Estate '73
Triumph 2.5PI Saloon '69
Triumph Herald 12/50 '65
Mercedes SL55 AMG '02
Mercedes E320 '05
Mitsubishi Canter '01
Rolls Royce Silver Shadow '76
Fiat Ducato Motorhome '03
Postby FI Spyder » 03 Jul 2015 14:36
It's got no numbers!! :shock:
TonyS
Postby TonyS » 03 Jul 2015 15:42
That's a new fault then, the digits must drop off after a while... :roll:
seven
Postby seven » 03 Jul 2015 16:45
No, it's a special clock for people who can't tell the time :roll:
Triumph TR7 DHC '81
Mercedes E320 '05
jaybee
Postby jaybee » 05 Jul 2015 00:41
I can't work out how to even adjust the clock!
1981 FHC in Pimento Red.
Postby FI Spyder » 05 Jul 2015 01:08
Push or Pull (I can never remember which) the turn knob and turn clockwise or reverse depending on which way you want the clock to go.
jaybee
Postby jaybee » 05 Jul 2015 10:21
No knob or anything under the dash. I guess someone in the past been messing around. I'll have to dismantle it
TonyS
Postby TonyS » 06 Jul 2015 09:09
There should be two knobs under the dash next to each other, one is for the mileometer and one is for the clock.
An easy way to remember which one is which is that the one for the clock is always the one that you think is for the mileometer and the one you think is for the mileometer is always the one for the clock - always...
Postby dursleyman » 06 Jul 2015 09:52
TonyS wrote:There should be two knobs under the dash next to each other, one is for the mileometer and one is for the clock.
That is SO true. Perfect example of Sods law in action.
Postby FI Spyder » 06 Jul 2015 15:04
Mine are arranged the same way. :?
jaybee
Postby jaybee » 06 Jul 2015 21:01
Well I've decided on a radical fix. I'll do a New post Later.
letstorque
Postby letstorque » 10 Jul 2015 13:29
I fitted an oil pressure gauge in its place. Did the same on the Stag. :D
Daihatsu Copen.
Wolfie, the TRV8.
Triumph Stag.
VW T4 2.5TDi Camper.
Another VW Motorhome
If you ain't got 8, you ain't got enough.
Who is the randy Reindeer?
jaybee
Postby jaybee » 11 Jul 2015 08:38
letstorque wrote:I fitted an oil pressure gauge in its place. Did the same on the Stag. :D
See my new post. Battery Clock
mmi16
Postby mmi16 » 23 Jul 2015 02:51
My clock works when the battery is too low to start the car. When the battery has enough charge to start the car, the clock stops.
_______________________________________________
Man does not race by straight time alone!
Racing - an illness with no known cure!
You're never too old to have a happy childhood!
Users browsing this forum: No registered users and 12 guests
