Like to get rid of air pump emission system
Postby Odd » 09 Nov 2009 10:07
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> How is this for a near-term plan? Keep the air pump (little drag) system and cats for a while until the 4 bbl carb works well. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Sounds reasonable. You'll have trouble enough getting a 'murrican carb to work flawlessly as it is...
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Then remove the air pump system and replace it with new cats, exhaust maybe, headers maybe, and see if I will be happy with that. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> <u>If</u> you stay with carbs - don't bother with changing out the catcons.
They will be burned out with time anyway...
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Do those metal tubing inlets go into the exhaust manifold to feed the air sent by the pump? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Yes.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Plugging would be by bolt in the hole then? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Yes.
If you decide to go the headers route:
- I'd be interested to take on your cast iron manifolds and the <u>entire</u> air pump system (for dad's TR7V8)...
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Since it is in cast iron, should I stay with steel, or go with S/S or brass? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> I think most have used ordinary grub screws - but then they'll be a pita if you want to remove them later...
I'd use stainless with aluminium paste as lubricant.
InfilTR8
Postby InfilTR8 » 09 Nov 2009 20:15
Thanks, Odd. Over on this side, I/we have very little experience and parts resources for the Stromberg carb. Mine I am sure are completely dried up. Is there a quick test of serviceability? If I have to go thru a rebuild, I would rather swap in an Edelbrock 4 bbl. I have 8 years of experience with a Carter AVS (=Edelbrock Thunder) 4 bbl, which I rebuilt and tweaked. Had no problems once tweaked, which was rather easy.
I gotcha on the parts if and when I later go to headers. I will keep the cast iron all the while I work on the TR8 to get it running. I will not spend big until I know the car is good to go, as we say in 'murrica (better as 'Merica). [^]
How much does the second wedge (the trailer) weigh? What is it equipped with? Cooking, refrigeration, toilet, shower?
Ima TRyFixTR8 my first Triumph
Postby Odd » 10 Nov 2009 08:31
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> How much does the second wedge (the trailer) weigh?
What is it equipped with? Cooking, refrigeration, toilet, shower? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Gross allowed weight is 750 kg (1653 lbs)
but I guess actual weight when fully equiped for a weekend (or a week) will be more... [}:)]
It <u>will</u> be equipped with a semi-stow-away double bed, a running water sink, a 3-place propane stove,
a propane/12VDC/240VAC fridge, a propane-to-air heater system and <u>maybe</u> a Porta-Potti (emergency)
toilet. I'm still building (slowly!) the interior and haven't finally decided on some of my wilder ideas...
When I bought it they had gutted the entire inside, nothing was left in it - but I saw its potential... And:
It was the correct year model to make it the ultimate time-correct accessory to my '8. [:D]
InfilTR8
Postby InfilTR8 » 10 Nov 2009 23:36
Interesting, Odd. [:)] In the future I need to decide what type of RV, trailer, or nothing at all (=hotels) to move around with.
I located 1/4 inch s/s bolts, and larger. I don't know what size the air tubing connectors are. Not starting right away, tho. I want to plan a good Positive Crankcase Ventilation system, if the present system needs improvement. Do present owners find a need to improve that?
