My question is: Can I get to all four of these going thru the hole for the shifter? Can you get to them from the underside of the car? Anybody got any pictures? I have scoured the red covered shop manual for both the 7 and 8 and there is no mention of how to change them, which is wierd because you could probably take the car apart bolt by bolt and put it back with one of these.
The reason I am concerened is I do not want to have to drop the transmission because a) I am not that smart or talented, and b) I replaced the rubber goo of a transmission mount about a year ago and when I did the bolt that runs thru it into the transmission housing basically just fell out on it's own because everything was striped and I had to put a coil insert in to get it to go back together. It is all nice and solid now, but I don't want to temp fate by trying to take it out and put it back in.[:p]
