Spent Some time in the garadge last night and here is what I did. Took out the dash and dismanteled the instrument pod and removed the speedo and tach. Removed the four green light covers and replaed lights with a flexible LED strip light. I placed them all the way around the Speedo and tach and left the tail end between the outer most guages. Above the radio I removed the bulbes and again replaced with flexible LED stip. As you can see I still have to do something with the Lights for the switches. Here are the results.
[img][IMG]http://i605.photobucket.com/albums/tt136/bendder/041610007.jpg[/img][/img]
[img][IMG]http://i605.photobucket.com/albums/tt136/bendder/041610008.jpg[/img][/img]
[img][IMG]http://i605.photobucket.com/albums/tt136/bendder/041610006.jpg[/img][/img]
So what do you think? I thought the red would be more fitting seeing as the seats and carpet are red and red check. Thoughts?
1977 TR7 FHC
1978 TR7 FHC
1980 TR7 DHC
1980 Rover SD1 4.0L
