Hello,
I have a very annoying small oil leak from the pulley, i have changed the oil seal but after a journey i have oil in the bay.
I check the oil regularly and all seems ok with the level.
Final question with the pulley off should i be able to see the oil thrower inside the timing cover? if not fitted do you think this could be the cause.
Thnaks for you suggestions Higgie
