Postby Dan B » 15 Aug 2009 13:36
Hey John,
The wire that was dangling....was that near the carbs? I had one like that. It turned out to be the wire for the throttle jack. Mine is an A/C car, so it has a throttle jack to raise the idle when the AC is turned on. That shouldn't have any effect on your power.
When I first got my TR4A, there was crud in the gas tank, even some leaves and debris. The fuel pump would draw it toward the tank outlet, which it would plug up, sometimes slowly, starving the car for fuel. I had to take the tank out and clean it out. I was surprised at all the stuff that came out. Some of the pieces were big enough to cover the outlet without going into the pipe. Could it be something like that?
