....What should I do with these[:I] clean answers only please...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
OK if that pleases you, here goes for the clean answer [:p]
<ul><li> 1. Two parts bottom left fit to the "A" post. Piece to the left fits lefthand footwell</li>
<li> 2. Vinyl trim pieces bottom cntre fit to the "B" post were the hood frame is mounted (see piccies below)</li>
<li> 3. The carpet pieces bottom right fit over the inner rear arches, with the edge facing outward (also see piccies below)</li>
<li> 4. Large piece of carpet top right (should have a base board underneath) lies on rear shelf with holes (for seat belt mount) facing to the front</li>
<li> 5. Two pieces bottom left fit to the outside of the vertical rear panel, covering most of the trim pieces mentioned under 2. Curved edge faces down </li>
<li> 6. I am missing the trim piece for the central vertical section in your picture.</li></ul>
<center>
